Rear Shock Rod Nut Size???
9 replies to this topic
  • Yamaryder29
Posted January 06, 2012 - 03:12 PM
I'm working on my 08 yz450f rear shock and need to purchase a new nut for the end of the rod, where the shim stacks are. I need to know what size the nut is so i can use a tap and die set to clean the rod. The old nut is junk and can't be reused.
  • crf450319
Posted January 06, 2012 - 04:34 PM
I'm pretty sure it's 1.50mm thread, I just had a KYB shock apart and used the 1.75mm thread die... that was the wrong size it was too big. Here's a replacement nut, note that it states 1.50mm.
http://www.moto-pro....strMPSID=MPKSSN
  • Yamaryder29
Posted January 06, 2012 - 04:39 PM
Thanks, I just order a locknut from suspensiondirect.com
Posted January 06, 2012 - 04:40 PM
It's an M12x1.5. Try to get an all metallic low profile lock nut.
  • crf450319
Posted January 06, 2012 - 04:48 PM
Yep, the exact nut in the link I posted I believe, lock aside. I use high stregnth loctite on mine.
Posted January 06, 2012 - 05:25 PM
Me too. Along with the lock nut.
  • Yamaryder29
Posted January 06, 2012 - 05:31 PM
The one I ordered is the KYB locking nut. I also plan on using loctite with it.
  • crf450319
Posted January 06, 2012 - 06:04 PM
Wouldn't that suck if that nut ever loosened off ? Ugh/ouch..
Posted January 06, 2012 - 06:08 PM
I've had them back apart a number of times. It's never been a problem.
  • crf450319
Posted January 06, 2012 - 06:36 PM
I meant loosen off to the point where the piston/shims are able to come off the shaft. I wouldn't think it'd feel good off of a 100+ foot jump.
