The STEALTH LED bar is the next generation of LED lighting! The 40" STEALTH LED Bar is perfect for UTVs, Sand Rails, Jeeps, Race Vehicle and packs 14,000 Lumens and that will truly annihilate the night. Comparable to running 4 HID lights yet weighs only 6.8 lbs and significantly increases aerodynamics the STEALTH bar is the new generation of LED lighting.
Internal Amtel Microprocessor ensures proper thermal management and access to the medium/dust mode and strobe mode which is perfect for daytime safety, signaling your chase support crew or getting your buddies attention at the hill.
If your looking for the ultimate in LED lighting technology the Baja Designs STEALTH is your answer!
* Front Lens: Hard-coated Polycarbonate
* Power Consumption: 168 watts
* Input Voltage: 9-30 volts
* Emitter: CREE XPG LED, 5500 Kelvin
* 42.3” Long, 1.5” High, 3.0” Inches Deep
* 50,000 hour LED life expectancy
