Hey All,
First off, Happy New Year! I have a big problem with my new-ish to me 1998 320 Gas Gas. I've had the bike 3 months or so. She was pretty hammered when I got her so I tore her completely apart, fixed broken welds, replaced nearly everything, bearings etc. The motor was left as is. Carb cleaned, but left as is. Reeds have NOT been inspected.
After the tear down I've ridden it a ton. Maybe 40 sessions. 1-3 hours per session. It's my first trials bike and also first two stroke, so I really have no point to compare the bike. It seems to run like a champ. I have 20+++ acres of California Coastal Redwoods in my yard and a typical ride is a bunch of short loops linked into a trail ride, cruising trails then blasting sections. The longest climb is probably 500-700 vertical feet with interruptions.
So everything is going great in my trials life until I do a 2500ft descent and high speed climb. Pretty much flat out trail ride on groomed single track and tarmac, maybe 12 miles non stop. Midway through the climb out the bike is down on power a bit and detonating at mid to high RPM. Just a bit, not extreme. It never pings normally except just the slightest hint right off the bottom when you rev it NOT under load. So I stop mid-ride and smoke is pouring out of the pipe at idle and the whole pipe and cast "expansion chamber" are stinking hot. Just thick nasty smoke. We can't stop where we are so I blast off another six miles of tarmac climb and park the bike. The exhaust smokes for 20 minutes and remains very hot after the rest of the motor is cool.
Ride my normal loops next morning. No problem, bike is normal.
The Fire: New Year's Day. Redding Dirt Riders annual Poker Run at Shasta. 40 miles or so. Sustained 5-6th gear pinned. Stop about 15 miles in because my leg is so hot I can't continue. Total plastic meltdown on fender/seat and plastic heat shield anything plastic near the exhaust. About a pound of molten plastic on my boot. Everything smoking. At speed the whole thing was staying cool enough to not go alight, but after a minute sitting someone kindly pointed out that flames were breaking out. Not big flames, more like multiple candles and fiery drips. Put the bike out with Camelback. DNF. Rode the return trip at a moderate pace and the bike was fine. Starts normal, runs normal.
It seems obvious that I'm over-taxing the bike in its current state of tune, but I know this bike is capable of doing these types of rides. She just wants to haul ass on occasion, I know it. I'm running 100 octane at 80:1 Redline. Fresh coolant made of Redline Water Wetter. I'm 230 lbs plus gear. Muffler clogged with goo? Jetting funky? Motor tired?
Thanks in advance.
Matt
