bike runs decently... i'm hoping the first issue is b/c it's cold. the second, i'm simply not familiar with the KTM just yet, so a little point in the right directly would be greatly appreciated.
1. start the bike, let it idle for a bit (~2 minutes), then head out around the block. cruises for a bit, then when i romp on it it stutters and THEN kicks in. thoughts? could it just still be cold? if so, that's easy... if not, where should i start looking?
2. the rear caliper is holding the rear pads ON the rotor - as in, i can smell them getting burned up after a quick run around the block... i have a feeling this has something to do with the new caliper installed after the bike got blown over by wind and insurance replaced it b/c of a scuff. brand new pads, just wonder if the reservoir is too full or what. simple enough... i hope.
thoughts?
