First of all, how much do you weigh? You need to obtain the correct rate springs for your weight before you do anything else to the forks. You should be using a 5wt oil, maybe 7wt max. Any higher and the shims in the valve stack will not deflect when their supposed to, making the ride harsh. When you say "max out" the oil level, what does this mean? There should always be an air gap.
Anyways, a little research shows that there are several bikes that use the same size fork springs (diameter and length) as the RMX. Here's the list:
2002 KTM 520 MXC
2002 KTM 520 EXC
2002 KTM 400 MXC
2002 KTM 400 EXC
2002 KTM 300 EXC
2002 KTM 250 EXC
2002 KTM 200 MXC
2002 KTM 200 EXC
2001 KTM 520 SX
2001 KTM 520 MXC
2001 KTM 520 EXC
2001 KTM 400 SX
2001 KTM 400 MXC
2001 KTM 400 LC4
2001 KTM 400 EXC
2001 KTM 380 SX
2001 KTM 380 MXC
2001 KTM 380 EXC
2001 KTM 300 EXC
2001 KTM 250 SX
2001 KTM 250 EXC
2001 KTM 200 MXC
2001 KTM 200 EXC
2000 KTM 520 SX
2000 KTM 520 EXC
2000 KTM 400 SXC
2000 KTM 400 SX
2000 KTM 400 EXC
2000 KTM 380 SX
2000 KTM 380 MXC
2000 KTM 380 EXC
2000 KTM 300 EXC
2000 KTM 250 SX
2000 KTM 250 EXC
2000 KTM 200 MXC
2000 KTM 200 EXC
1999 KTM 200 MXC
1999 KTM 200 EXC
1999 ATK 605 CC
1999 ATK 250 LQ
1998 Suzuki RMX250
1998 KTM 200 MXC
1998 KTM 200 EXC
1997 Suzuki RMX250
1996 Suzuki RMX250
1996 KTM 550 MXC
1996 KTM 300 EXC
1996 KTM 250 SX
1996 KTM 250 EXC
1995 KTM 550 MXC
1995 KTM 440 MXC
1995 KTM 440 EXC
1995 KTM 300 EXC
1995 KTM 250 SX
1995 KTM 250 EXC
1994 Honda CR500R
1994 Honda CR250R
1993 Kawasaki KX500
1993 Honda CR500R
1993 Honda CR250R
1993 Honda CR125R
1992 Kawasaki KX500
1992 Kawasaki KX125
1992 Honda CR500R
1992 Honda CR250R
1992 Honda CR125R
1991 Kawasaki KX500
1991 Kawasaki KX125
1989 Kawasaki KX500
1989 Kawasaki KX125
You can use the online database on
Racetech.com to find what the stock spring rates are for each of these bikes, if you are looking for cheap "take-offs" from the salvage yard or something. The stock springs in your RMX forks are .41 kg/mm, which is too light for anyone over 160-170 lbs.
