02 WR426 shock spring help/adjustment
No replies to this topic
  • TEDean
Posted October 01, 2003 - 05:25 PM
Before I buy a stronger rear spring, just want to make sure I have to.
02 WR426
stock rear shock spring (5.0 rate)
spring length = 9.75 (adj to 9.47 or about 0.25")
my weight = 210 (225/gear)
race sag = 114.3mm (4.5")
static sag = 36.5mm (1.5")
Do I have any hope of adjusting this to at least a 100mm race sag?
If I have to replace the spring, if you unscrew the adjustments all the way, will the spring become removable by hand, or do I need a special tool.
Is 14mm really too much sag if I'm mostly ride on the MX track (jumps and woops)
I appreciate you comments
