easy pull clutch system
1 reply to this topic
  • mxcowboy
Posted July 30, 2001 - 04:53 PM
Moose has one on their site. It's a leverage box that goes between perch and cable and was wondering if anyone has tried this and how it works? thanks for your input.....
  • jbird
Posted July 31, 2001 - 03:14 AM
mxcowboy, I have run these on two previous bikes and they work really well. They have three settings you can try. The only thing I didn't like is the fact the effectivly make your clutch cable about 6 inches longer and could cause routing issues. The other is that they won't work with the stock YZ cable because the diameter of the cable itself is too thick. It won't fit into the housing of the easy clutch.
So anyway, if you have an aftermarket cable and don't mind the extra length give it a shot. It will make the pull easier and they don't cost very much either.
Jon
01 YZ426F, 99 YZ400F, 86 XR250, 76 RD400, 71
Heavily Modified Z50
  • Hot  36 replies
  • 0 replies
  • Hot  113 replies
