1985 cr500 cdi unit
2 replies to this topic
  • eladracing
Posted December 29, 2011 - 11:02 AM
hey cr fans.
Does anyone know if the CDI unit of cr125 or 250 is also suitable for 500?
  • gixxerbob
Posted December 29, 2011 - 07:09 PM
i rewired a late 80's cr125 and another late 80's cr250 ignition to my 1985 cr500 motor. both looked identical with the same wire placement and color codes. i used the magneto diaghram from a 1984/85 cr250/500 and the cdi diaghram from 1986-87 cr250/500 in the clymer book. i assume my motor came with a cr500 magneto/flywheel since all the wires were correct according to my clymer manual. as long as you wire it correct i dont see why it wouldnt work, the ignition maps are different and it might have a different redline but it will fire and run.
you may have to wire the blue wire comming out of the cdi box to the white wire as they are both stator pickups to achieve higher rpm's. i forget if i did that or not.
fyi ** the clymer diaghram for the cdi part said that b/y (a black wire with yellow stripe) was y/b (a yellow wire with black stripe)..... i feel it was incorrect and opposite
im going to upgrade to a newer 2002+ ignition set up soon since its reasonably priced and a nice upgrade.
Edited by gixxerbob, December 30, 2011 - 09:39 AM.
  • eladracing
Posted December 30, 2011 - 07:56 AM
I installed a 96 cr125 cdi and it did spark.
Thank you.
2006 cr 85 running bad/ sputtering by Honda2smokerider23
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
  • 0 replies
Is the stroke coming back? by MazdaMan
  • Hot  80 replies
Cr250 acting very strange.....HELP by bodedibblesjr
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  52 replies
Honda CR500AF Action Video by HeddleTown
  • 2 replies
2003 CR250 by asealy20
  • Hot  34 replies
