to lube or not lube?
3 replies to this topic
  • tomtom1
Posted December 28, 2011 - 10:14 AM
Hi All This maybe a daft question,but iv'e just fit new renthal front and back sprockets, with a new did race chain for my wr450 2003 and it's all nice and clean and lubed from new now
but should i lube it before my first ride out as the sprockets are dry also whats the deal with cleaning them i get in some pretty muddy stuff so i steam the bike off every ride (avoiding bearings electrics etc) whats best way of cleaning the thick mud off? iv'e done a search but couldnt find anything about lubeing a new chain sprocket set thanks for any advice
  • MANIAC998
Posted December 29, 2011 - 03:36 AM
Everyone has there own method of cleaning/lubing a chain. A soft nylon bristeled(?) brush and gently scrubbed by hand is how I clean mine. Then I fire up the bike while it's on the bike stand, place the bike in gear, and let the rear wheel spin for a couple minutes. This helps warm up the chain and dry it out. Then before I shut it down, I'll spray it with something light like WD40. Of course, this is with an O-ring chain, as that's all I'll run. Maniac
  • wrwest
Posted December 30, 2011 - 04:52 AM
Only use wd 40 on your chain if you ride offroad .
Using oil or chain lube only makes the grit pack on your chain and makes a grinding paste.
This is for o ring and x ring chains only.
  • YamaLink
Posted December 30, 2011 - 06:31 AM
If the factory packaging gunk is super thick I'll clean all of it off. Otherwise a brand new bike or chain/sprocket combo is just begging to be ridden so a little chain lube does the trick. I prefer to oil a chain after riding when the metal is warm.
