Which is the top piston ring?
12 replies to this topic
  • Gibbit
Posted December 27, 2011 - 12:16 AM
Long time lurker, first post!
Just doing a rebuild on a 2011 YZ450F and am about to put the rings that came in the spares kit on a new oem piston.
Which is the top ring and which is the second?
1. Black and chrome in colour.
2. Grey in colour with a chamfer on its outer edge.
Cheers.
  • Gibbit
Posted December 27, 2011 - 02:18 AM
I have put them in, in the order that I decribed them. Ill see what happens. The top one also has the smallest ring gap which I think is right.
  • Gunner354
Posted December 27, 2011 - 06:38 AM
Are you kidding? Guessing on which ring goes where? Good luck! This is why I don't buy used bikes!
  • Wiz636
Posted December 27, 2011 - 08:21 AM
They should be of different thicknesses...check the ring grooves on the piston and compare to the thickness of the rings.
Posted December 27, 2011 - 08:34 AM
If they fit, they're in the right place. One is wider than the other, and they can't be switched. That's why they come with no identifying marks as to which one is which.
  • 2grimjim
Posted December 27, 2011 - 11:31 AM
If there are any marks on the rings, they face up.
Posted December 27, 2011 - 11:48 AM
That's one of the very few things that IS in the instruction sheets (most of them), but it's worth mentioning.
  • 2grimjim
Posted December 27, 2011 - 11:58 AM
My pop learned me a long time ago; men don't read instructions.
  • Gibbit
Posted December 27, 2011 - 01:27 PM
Thanks for the replies fellers.
I brought the bike new last year. I've put 120 hrs on it so I figure it's time for a freshen up.
I am replacing valves, valve cotters, valve stem seals, valve springs, piston, rings, piston pin, cam chain and cam chain adjuster. All OEM parts.
I tried that but both rings fit in both grooves.
The manual says the ring gaps specs are:
Top ring = 0.20-0.30mm
2nd ring = 0.35-0.50
I stuck the rings in the cylinder and they answered my question.
Yep...... there was a 'T' on them. :bonk:
Posted December 27, 2011 - 02:42 PM
... both rings fit in both grooves.
That's changed since the '08, then.
  • 2grimjim
Posted December 27, 2011 - 03:31 PM
Yup. '10 and later YZ's use a 1.2, 1.2, and 2mm ring set on some aftermaret pistons.
Generally, the top ring is plated on the ring face (chrome, for NiSC composite and Iron bores), and the 2nd ring is usually un-plated but will somtimes have a deposit of Moly in a thin groove in the center of the ring face.
  • crf450319
Posted December 27, 2011 - 03:38 PM
I was thinking the exact same thing....:bonk:
  • Gibbit
Posted December 27, 2011 - 03:48 PM
I have put them in the right way then.
  • Hot  30 replies
  • Hot  50 replies
  • Hot  28 replies
  • Hot  113 replies
