NEED HELP WITH MY YZ 426f
9 replies to this topic
  • yz426fX2
Posted December 22, 2011 - 09:00 PM
Hey guys so i have two yz 426fs and they both have the same problem.....they will start right up with the choke out but literally the second its pushed in they die....all the jets in the carb are clear so im kind of stuck....ANY imput would ge great
Dave
  • yz426fX2
Posted December 22, 2011 - 09:09 PM
And my float is set correctly as well i forgot to mention
Posted December 22, 2011 - 09:54 PM
It sounds like the idle circuit is lean or blocked. I know you said the jets were clear, but a pilot that looks clear can be 40% or more obstructed by a varnish deposit you can barely detect.
Read: http://www.thumperta...726#post8021726
Also check the hot start plunger to make sure it closes, make sure there's on O-ring on the pilot screw, and check the vacuum release plate on the engine side of the slide. It's a common mistake to assemble them upside down (the square edge goes down, not the half round one), and they will crack or chip due to wear and cause all kinds of trouble.
  • yz426fX2
Posted December 23, 2011 - 07:02 AM
Where does the o ring on the pilot screw go?
  • frankie_b_jr
Posted December 23, 2011 - 05:42 PM
The order coming out should be... screw, spring, washer, o-ring. The o-ring might hang in the carb when taken apart then fall out as it relaxes. Two days of cussing before i figured mine out.
  • oakasrtheshiz
Posted December 25, 2011 - 03:37 PM
i had the same issue on my 01 426. i changed the pilot jet from the stock 42, to a 45. the bike has a fmf power bomb header & fmf power core muffler and no lid on the airbox. the main jet is 68 and the fuel screw is set a 2 1/4. jet's are about $4 a piece, i see no reason to even think about drilling out a jet
Posted December 25, 2011 - 06:04 PM
No one is suggesting drilling a jet.
  • oakasrtheshiz
Posted December 25, 2011 - 06:45 PM
i must have misunderstood that link then. i apologize
Posted December 25, 2011 - 09:43 PM
What I said was to use a drill as near to, but no larger than, the jet size to clear a varnish deposit, holding the drill itself in your fingers, preferably. In fact, I usually recommend pushing the shank of the drill through, rather than the cutting end.
  • Brit7732
Posted December 28, 2011 - 12:44 PM
Had almost the same issue on my 02 426, would start on choke fine then would barely run with the choke off, had to keep the idle high to prevent it from shutting off.
When trying to rev it or ride it, backfired real bad. Cleaned the carb and jets thoroughly, twice, no change.
Turned out to be a bad CDI unit, as soon as the RPM's increased the timing went all to hell.
  • Hot  38 replies
  • Hot  36 replies
  • 5 replies
  • Hot  30 replies
