installing new piston should I do anything else?
25 replies to this topic
  • KJK_JR
Posted December 22, 2011 - 03:28 PM
I am currently installing new piston/rings and cam chain on my 09 and was wondering if I should do anything with the head (valve seals, springs,etc). The bike has 3 seaons of use with unknown hours. Only two intakes and one exhaust valve have been adjusted once and haven't moved two seasons later.
  • 2smokeforlife
Posted December 22, 2011 - 03:34 PM
just check every thing to see if it is spec. replace what is out of spec
  • 2grimjim
Posted December 22, 2011 - 04:24 PM
Since you are going to have the head off, I'd pull the valves and inspect them. The valve 'face' (the angled part that contacts the seat) will have a bright line where the valve contacts the seat. The edge of the bright line should not have a detectible step. If you can feel a step when you run your fingernail across it, it may be time to replace valves and re-cut seats.
  • KJK_JR
Posted December 22, 2011 - 05:08 PM
Okay i guess disassembling the head is a good idea. If everything looks good and measures within spec should i just replace the valve seals and clean everything up? What are good methods of cleaning the valves? Anything I shouldn't do...Obviously not use sandpaper.
  • 2grimjim
Posted December 22, 2011 - 05:14 PM
You can use #000 or #0000 steel wool or some broke-down green or white Scotch Brite to clean the valves. You can also use a wire wheel on a bench grinder if you are very careful.
Make sure you use some good moly paste on the valve stems when you pur everything back together.
  • crf450319
Posted December 22, 2011 - 05:20 PM
While you've got it apart, for $20 I'd put a new cam chain in it..
  • Gunner354
Posted December 23, 2011 - 02:24 PM
The easiest and I believe is the best way is to make sure the valves are closed and spark plug is in the head. Turn the head upside down and fill up chamber with WD40 and let it sit at least over night. Pour out WD40 and wipe all carbon away with a rag. Works awesome.
  • 2grimjim
Posted December 23, 2011 - 02:27 PM
Oven cleaner also works good too. Just keep it confined to the valves.
  • Krannie McKranface
Posted December 23, 2011 - 05:06 PM
...then do a leak test to see if the valves still seat!
  • KJK_JR
Posted December 23, 2011 - 07:33 PM
disassembled the head...not sure if pics are good enough to say anything
Exhaust valves:
Left
Right
Intakes:
Left
Middle
Right
  • KJK_JR
Posted December 23, 2011 - 07:35 PM
Some pics of the head....again don't think the pics are good enough to say anything
  • 2grimjim
Posted December 23, 2011 - 09:12 PM
Aside from the carbon build-up on the valves, they dont look too bad. Clean them up good and post new pics.
Try runnung come Chevron Techron concentrate or BG 44K on a regular basis and you shouldn't have any carbon build up.
  • Family Man
Posted December 24, 2011 - 12:24 PM
dont forget to put in a new spark plug.
  • BBrown626
Posted December 25, 2011 - 01:02 PM
You lack a good clean seating surface. The carbon buildup is likely holding your valves open a tad. be sure to clean all that stuff from the head and valve.
You didn't mention replacing your valve stem seals. They are cheap and they are easy to replace.
  • KJK_JR
Posted December 25, 2011 - 01:30 PM
yes I'm gonna clean everything up really good. Yes I will replace the valve stem seals. Should I replace the springs even if they are within specification?
Posted December 25, 2011 - 06:52 PM
Intake 'M' shows signs of cupping.........
  • KJK_JR
Posted December 26, 2011 - 02:36 PM
what indicates signs of cupping?
  • KJK_JR
Posted December 27, 2011 - 05:03 PM
well its looking like im just gonna replace all the valves with pro-x stainless steel ones. Of course i'll use the appropriate springs and have the valve seats recut. The cylinder is in questionable conditions as well. Almost looks like the plating is worn through at the top.
  • KJK_JR
Posted December 27, 2011 - 06:30 PM
so looks like i may have other problems as well. The area in the cylinder head where the valve lifters reside appears to have scratches and wear marks. According to the manual if these scratches exist it says to replace the cylinder. So before I start panicking what do you guys think?
Posted December 27, 2011 - 08:28 PM
For one thing, that's not the cylinder. Minor scoring in the lifter bores is not necessarily something bad enough to warrant replacement of the head. If the lifter fits well, has acceptable clearance, and moves freely in the bore, it's serviceable. You may want to knock down any high spots with some fine sand paper (but CLEAN it up if you do), but that doesn't look like a deal breaker to me.
  • 9 replies
  • Hot  47 replies
