Green oil-------Help
8 replies to this topic
  • blitzer544
Posted September 30, 2003 - 04:32 AM
Ok. I changed my oil yesterday and when I pulled the drain plug the oil was green. I know the first thing I thought of was antifreeze in the oil. If this is so does antifreeze and oil mix? There was no separation of the oil. I have a big ride this weekend and I think I have big trouble. Any one have any ideas?
  • Indy_WR450
Posted September 30, 2003 - 05:20 AM
What kind of oil are you using? :)
  • blitzer544
Posted September 30, 2003 - 05:25 AM
Kendall 20-50 4-stroke motorcycle oil
  • Drew_Seattle_DRZ400s
Posted September 30, 2003 - 02:16 PM
Have you checked your coolant level to see if it has dropped?
  • GrahamO
Posted September 30, 2003 - 02:58 PM
I'd watch out for Drew's advice. He smokes green stuff. If he asks you for a sample I'd recommend NOT sending him anything.
  • unkle_george
Posted September 30, 2003 - 03:05 PM
If you have water in your oil it'll be white or grayish and chunky... not green. (unless you're running straight antifreeze)
Also, if you're getting water in your oil, you're probably also getting oil in your water. Check for that too.
- Ryan
  • james_b
Posted October 01, 2003 - 05:19 PM
put some of the oil in a glass jar and shake it up. If it foams there is antifreeze/water in the oil..................
  • RichBaker
Posted October 01, 2003 - 07:15 PM
IIRC, Kendall is green colored....
  • blitzer544
Posted October 02, 2003 - 05:09 AM
Thanks for the responses. I put the oil in a container and let it sit for hours and checked it. It never separated, so I assume everything is OK. It just really freaked me out when I saw green pour out of the bike. :)
