06 backfires no start
10 replies to this topic
  • TwIzTeD NuTz
Posted December 20, 2011 - 02:41 PM
I have an 06 YZ450 that it will no longer start it only back fires. where should i start? timing has been checked, valve clearances adjusted,carb gone through. it just back fires through the exhaust. any input??
Posted December 20, 2011 - 04:29 PM
When you checked the timing, did you verify that the marks on the flywheel were aligned with TDC?
  • 2grimjim
Posted December 20, 2011 - 04:36 PM
Silly questions;
How long since you rode it last?
What's the sparkplug look like?
How old's the gas?
Was this a progressive problem? i.e. Was your bike having hard starting problems that got progressively worse, to the point of not starting at all?
A little history of the problem will help a lot.
  • TwIzTeD NuTz
Posted December 20, 2011 - 05:07 PM
timing was verified with the marks on the flywheel and also with the piston.
Silly questions;
probably last time it ran long enought to ride it was september. I have been fighting this problem since then.
How old's the gas?
gas is fresh. just put it in this morning.
it was getting progressivly harder to start. and then it got to the point that all it would do is back fire, and here i am today asking for some help :bonk:
  • TwIzTeD NuTz
Posted December 20, 2011 - 05:08 PM
also, the bike has a vortex ignition, I do not have a stock ignition to swap out to test though.
  • capt justin
Posted December 20, 2011 - 05:15 PM
replace that plug with a new one
  • 2grimjim
Posted December 20, 2011 - 06:56 PM
Are you getting a consistant spark at the plug with it stuck in the coil and grounded on the engine?
  • TwIzTeD NuTz
Posted December 20, 2011 - 07:12 PM
I would not say its consistent, it seems very weak truthfully.
  • 2grimjim
Posted December 20, 2011 - 07:34 PM
Hmmm..... without being able to swap in the stock CDI you'll have to throw the dice and buy a CDI. If you pin check the coil and stator and they spec-ok you really don't have a choice.
Do try replacing the plug first though, if you haven't already done that.
  • TwIzTeD NuTz
Posted December 20, 2011 - 08:11 PM
I'm picking up a new plug tomorrow, I'm trying to locate a cheap cdi also.
  • 2grimjim
Posted December 20, 2011 - 08:25 PM
You have oter options other than a stock or Vortex CDI. Dyna makes a programable CDI (not quite as cool as the Vortex) for about $350 (retail). A little shopping you should be able to get one for under $300.
  • Hot  113 replies
  • Hot  38 replies
  • 0 replies
  • Hot  36 replies
