fuel leaking when bike is shut off
10 replies to this topic
  • sean9
Posted December 17, 2011 - 02:30 PM
my freind has a 2000wr400 and when his bike is shut off it leaks fuel what could be the problem.he has changed gaskets in the pepcock.
  • RasmusDK
Posted December 17, 2011 - 03:35 PM
then it leaking from the petcock?
  • sean9
Posted December 17, 2011 - 04:39 PM
thats what i thought but no it wasnt leaking
  • MANIAC998
Posted December 17, 2011 - 05:32 PM
Ahhh......yeah. I think we need more information. Such as, just where is it leaking from? With this information, we might be able to help. Maniac
  • sean9
Posted December 17, 2011 - 07:42 PM
sorry it is leaking from the overflow
  • newbernbears
Posted December 17, 2011 - 07:49 PM
I'd inspect needle and seat, needle may be stuck
  • MANIAC998
Posted December 18, 2011 - 04:19 AM
Like newbernbears said, I'd check the needle & seat first, and then check the float height too. Make sure it's in spec. You do have a manual, right? Maniac
  • miweber929
Posted December 18, 2011 - 05:25 AM
Or you could simply turn the petcock off when you are not riding. Amazing how many people don't do this one simple thing. If it still leaks you have a petcock anno it a carb problem like was mentioned; if not go for needle and seat and check the float height.
Mike
Edited by miweber929, December 19, 2011 - 05:59 AM.
  • 2grimjim
Posted December 18, 2011 - 11:16 AM
The float level may not be correctly adjusted. If you go the the trouble of removing the carb to clean it, you should make sure the float level is set @8mm too.
  • sean9
Posted December 18, 2011 - 04:48 PM
thank you everyone i will look at everything on the carb.and report back
  • Pooley
Posted December 19, 2011 - 12:43 PM
The o-ring that goes around the outside of the seat. They harden up over time and does exactly what you describe.
