WR 450 primary gear
6 replies to this topic
  • KTMFarmer
Posted December 15, 2011 - 08:20 PM
I am doing some work over the winter on my 2005 WR450. I am trying to remove the primary gear and I am having no luck removing the nut. I just broke the tip on my Cornwell screwdriver by wedging it between the gears while trying to loosen the nut.:bonk: Anyone have any ideas on how to keep the gears from turning in order to remove the nut. Thanks
  • The Hopper Show
Posted December 15, 2011 - 08:33 PM
gear puller?
  • MANIAC998
Posted December 16, 2011 - 04:31 AM
Use something soft instead. I like to use a penny. It'll deform enough to get bound up and stop the gears from turning. Just make sure you don't forget it!!! Maniac
  • YamRZ350
Posted December 16, 2011 - 04:51 AM
Lead sinker, Motion Pro sells a nice wedge tool, or just zap it with a rattle gun.
  • bg10459
Posted December 16, 2011 - 05:46 AM
Definitely use something soft to jamb between the gears...
  • KTMFarmer
Posted December 16, 2011 - 05:07 PM
I did the penny-impact wrench trick and it popped right off. THANKS
  • zibbit u2
Posted December 16, 2011 - 05:53 PM
I'd say use a penny and a 2ft breaker bar. I think the penny fell out because in between the pulses of the gun it removes tension... so.. that's when it would fall out.
