gytr power tuner
13 replies to this topic
  • reidy
Posted December 13, 2011 - 01:50 PM
thinking of buying a tuner, are they easy/simple enough to work?
  • glenn77
Posted December 13, 2011 - 07:53 PM
I got one with my bike. It took me 45 minutes or so to load 9 maps out of MXA and off this site onto it. It only takes seconds to change the map on your bike once its plugged in. All the maps that I loaded onto my tuner had a description of how they change your engine, I wrote that down on the manual so I know which one I'm going to try. For now I'm using the map that eases the hit down low, next year I'm going to try them all. It's very easy to use.
  • HRC
Posted December 15, 2011 - 11:38 PM
Very very easy to use. And fun for that matter...
  • reidy
Posted December 16, 2011 - 10:47 AM
do i have to download programmes onto power tuner? does it cost for downloads?
here in uk they are about £230 pounds so mite wait til new year and get one from usa!
Posted December 16, 2011 - 11:12 AM
Programs, or maps if you will, are entered manually. You can either use the ones listed in the sticky in this forum or make up your own as you go. Costs nothing, and as I recall the tuner can store up to 9 maps that can be selected and loaded into the ECU. The ECU will only hold and utilize one at a time.
  • reidy
Posted December 16, 2011 - 12:47 PM
sounds good, will def have to try one!
it sounds simple enough to use and could be good fun. thanx guys.
  • dalonar
Posted December 16, 2011 - 04:48 PM
fun, good tool to use for maint...very easy and straightforward to update/enter maps. One thing i wish i could lable maps but a cheat sheet in the gytr box keeps my map numbers organized
  • sir speedy
Posted December 26, 2011 - 05:55 PM
Just bought a programmer - its on the way now. My question is how do you hook it up? Does the little black harness on the bike slide down or up? It looks like its mounted to a metal clip> Do you pinch the bottom and slide up or what? Don't want to do anything until I know for sure. Thanks in advance.
  • Bulldog5150
Posted December 26, 2011 - 07:56 PM
Agree completely with Glen....tuner is easy and fun! I think the other manufactures miss the boat by not having a comparable device!
  • tech24
Posted December 27, 2011 - 05:15 AM
pull out on the little tap sticking out and pull the harness connector out of the plastic retainer (not the metal clip)
  • HRC
Posted December 27, 2011 - 12:02 PM
Works the same both on the tuner and bike...
  • sir speedy
Posted December 28, 2011 - 10:39 AM
Thank you Thank You Thank You
  • reidy
Posted December 29, 2011 - 11:22 PM
thats power tuner ordered, cany wait til it comes.
  • Iaskdumbquestions
Posted August 31, 2014 - 12:58 PM
please repost these pics
  • Hot  36 replies
  • 5 replies
Motocross
  • Hot  491 replies
  • 9 replies
