Wr450 highway duties ?
6 replies to this topic
  • Stealth13
Posted December 13, 2011 - 08:25 AM
On stock gearing how would the wr450 do cruising at 110-120kmh? Is there a better gear to get if I do alot of street riding as well as offroad too?
  • Sknight
Posted December 13, 2011 - 10:06 AM
Mine is turning about 7500RPM at those speeds. That's a lot of wear and tear, regular oil changes and just putting up with the engine screaming that much would be a pain.
I have considered getting a set of more street friendly gears and chain to swap between dirt and street duty but for now I just keep the street duty to side streets and local roads.
It'll do it, just not very well.
  • Stealth13
Posted December 13, 2011 - 10:15 AM
What would be a better sprocket size for that kind of riding so it's not wringing it's neck, but so I can also ride trails?
  • Snarfie
Posted December 13, 2011 - 11:37 AM
15/40 would be a good start.
  • Stealth13
Posted December 13, 2011 - 11:58 AM
What is the stock gearing and if the number goes up is that higher or lower rPm at cruising speed?
  • bg10459
Posted December 13, 2011 - 02:16 PM
Stock gearing in 2003 was 14/50. I think it changed sometime after that to 13/50 (05?). I have run 15/48 on my 03 and didn't miss much down low since 1st is already so low. Top speed was notably improved.
Bigger sprockets in front and smaller in back lower rpm for any given speed at the expense of low speed torque.
  • Stealth13
Posted December 13, 2011 - 08:38 PM
Mine is an 06 . Know what the gearing is in that?
