The choke lever on my little brother's bike will not stay engaged. You have to hold it down, which is a pain, especially since it's a cold blooded son of a gun. It is a 23mm mikuni i believe, and the choke is at the top of the carb.
I remember reading that there may be something gummed up inside that is causing this? Any basic knowledge on what to look for would be helpful.
Forgive me, I know i've read this somewhere on this forum, but I can't find it again for the life of me. I think it was posted by Krannie...
Choke won't stay engaged.
Started by
Dezert_Man
, Dec 09 2011 04:49 PM
9 replies to this topic
Posted 09 December 2011 - 04:52 PM
It might be gummed up inside, take some carb cleaner to it and clean it out well
Posted 10 December 2011 - 04:20 AM
Normally, you replace the lever/knob assy, the detent is worn out. Please also post the make, model and year of the bike so more specific information may be provided if applicable.
Posted 10 December 2011 - 12:26 PM
I have the same problem on my GasGas' PWK carb. I keep a mini-bungee cord wrapped around my handle bars, so when I need the choke, I take the cord and hook one end of the cord to the button and the other to the rad shroud to hold it up. It's ghetto, I'll admit, but I refuse to put one extra penny into that sh*tbox.
JayC
Posted 10 December 2011 - 10:28 PM
05 Suzuki drz125l. I refrained from posting it to prevent the thread from being moved. I apologize.
Posted 11 December 2011 - 05:11 AM
Well, that is the wrong thing to do. All posts regarding a bike belong in the appropriate forum. There are many types of carbs. There can be mutiple types of chokes. You are asking for everyone to give you an explanation of style choke and every style carb because you do not want to divulge the bike.
Posted 11 December 2011 - 03:14 PM
Once again, I apologize. I have found that most of the information I get to help fix my bikes comes from other forums, rather than the forums they belong to. I will refrain from doing this in the future.
Posted 12 December 2011 - 09:48 AM
Mine wont stay up either... you could replace the plunger. While your in there fatten up the pilot jet a little and it will start a lot easier, then you wont need the choke as much.
Posted 14 December 2011 - 05:35 AM
Did you try tightening the screw on the pivot? It should do something positive, if only for the short term.
