On my ktm 620 egs. Any likely suspects? And if for example it's the sel behind the sprocket is it an easy DIY fix?
Slight oil drip near kickstart
Started by Ohffs, Dec 08 2011 11:33 AM
5 replies to this topic
Posted 08 December 2011 - 11:33 AM
Posted 08 December 2011 - 11:42 AM
If it is coming out of the kickstart then it is probably the seal. Not a hard fix, you need to pull the cover off and pop the seal out. You need to figure out exactly where the oil is coming from first though.
Posted 08 December 2011 - 12:25 PM
Thank you very much. Im so pleased to have had replies all ready as iv joined other forums and not had much luck. I'm new I all this coming from road bikes.
Posted 10 December 2011 - 08:40 AM
Now then I grabbed a pic. (excuse the filthy bike!)
It's only dripped the once but obviously I know realise it's the opposite side to the sprocket! I'm gonna give it a really good clean over the weekend the. Keep an eye on it but won't be using it too soon as te forks are leaking too :-( lol
Posted 02 January 2012 - 12:22 PM
Right iv got the fork seals done and been for an awesome ride today however there is still a slight leak here. Am I better doing this at the same time as an oil change (does the oil need to be drained?) are any special tools required and finally where can I source a seal for this or what is it called?
