Leaky radiator fluid.
4 replies to this topic
  • iceee187
Posted December 06, 2011 - 05:41 PM
2006 yz 450 high comp piston, full exhaust, non oem top end gaskets.
Ofter a rebuild I have fluid coming out of the front cyclinder head flange. leaking a drop a second. very notciable. Everything is in spec of tightness. could my head gasket be blown some how. Its a tuck offraod gasket. ask and I can give u more details.
Posted December 06, 2011 - 07:40 PM
Check for a coolant leak at the joint between the head and the tube where radiator hose connects to the top end.
How did you do your cylinder head torque?
  • iceee187
Posted December 07, 2011 - 02:42 AM
there is no leakage from the head gasket anwhere, it seems to still be coming from the front flange. Just put a OEM oring in the front top head cylinder head rad intake flange.
I did a 22 ft lb then a 180 degree turn on the bolts???
  • iceee187
Posted December 07, 2011 - 02:43 AM
its a 14.1 comp piston???
Posted December 07, 2011 - 08:06 AM
That would be overtightened. You're supposed to pretorque to 22 ft/lb, then loosen the bolt and retorque to 14 ft/lb, THEN turn each bolt another 180 in 90 degree steps.
Read:
http://www.thumperta...ad.php?t=972816
As far as the leak, if it persists from the outlet tube, inspect the socket the tube sits in as well as the tube and the O-ring for damage.
  • Hot  113 replies
  • 10 replies
  • 0 replies
  • Hot  38 replies
