426 very weak spark
No replies to this topic
  • wack01
Posted December 04, 2011 - 12:31 PM
Hi have an issue after washing and degreasing my bike. I started the bike up after letting it dry for a bit and it ran and sputter off. I have a very weak spark, You can't even see it, only if I kickover the bike and feel a very weak spark.
I checked all the connections with a ohm meter and found that the coil was out of spec, so bought a used one same results. So then I decided to do the coil on spark mod with a denson coil still very weak spark.
I also checked the stator and cdi box with ohm all with in specs.
I cleaned all the connections with electronics cleaner also.
I made sure the ground was good on the coil also.
Killswitch works also.
Also installed a new spark plug
So what gives? :foul:How many ground points are on this bike? maybe if clean them it will work?
Also the bike has both hotcams installed.
Any help will be appreciated thanks
  • Hot  50 replies
  • On January 15, 2017
  • 0 replies
  • 9 replies
