Which bearings to buy OEM or aftermarket ?
4 replies to this topic
  • still2smokin
Posted December 03, 2011 - 12:27 PM
So I picked a 05 wr450 and I want to replace all the bearings- steering,
shock, wheel, linkage and swing arm. My question is which ones aftermarket
or OEM ? I have used All Balls and Pivot Works in the past on my old 2 stroke
but they never seem to last longer than 2 years. Do you guys think the OEM
Yamaha bearings will last longer than the aftermarket replacment sets ?
  • tsorpi
Posted December 03, 2011 - 12:49 PM
mine has pivot work in swing arm and linkage prety good bearings
  • camman
Posted December 04, 2011 - 11:49 AM
No they will not. Dirt wears out bearings in dirt bikes.
  • GuyGraham
Posted December 04, 2011 - 01:02 PM
As said above, its not the quality of the bearings that is making them fail but the ingress of water and dirt
Keep out the water and dirt, and aftermarket bearings will last years
Yamaha don't make bearings, or have 'special' quality bearings made - they are just off the shelf std engineering bearings
I buy Koyo bearings where possible, coz they are a quality brand often used by the Japanese for wheel, suspension and engine bearings
The other brand often used by the Japs is NTN
either of these or makes such as SKF will be fine
Its your seals letting you down
  • BajaFool
Posted December 04, 2011 - 01:23 PM
I agree with GuyGraham's comments. I would add that sticking with bearings manufactured in the USA, Japan or Germany (not China, countries of the former Soviet Bloc, India, etc.) is an extra ounce of caution. The country of manufacture is noted on each bearing.
