1998 YZ400 F Flywheel swap
6 replies to this topic
  • ktmheinzee
Posted December 03, 2011 - 10:05 AM
I have a 1998 YZ400 F that I just pasted down to my son. The bike is in great shape but he has truble keeping it running in the slower tight stuff because the flywheel is so light. I was going to add weights, but you cant find them anymore, so does anyone know if a WR 400 flywheel from the same year or 1999/2000 will fit/work.
Thanks
Posted December 03, 2011 - 10:09 AM
Yes, it will work, but you'll need the WR stator to go with it, and you'll need to modify the stator to work with the YZ ignition:
http://www.thumperta...52#post10674552
  • RasmusDK
Posted December 03, 2011 - 04:33 PM
Hi see this http://www.steahlyof...eel-weight.html
Its the only ones i can find, I had the same thoughts. But i guess with a weight like this you gotta get it SPOT ON or re-balance the flywheel... so yea the wr wheel probably is the way to go..
  • baxterj787
Posted December 03, 2011 - 06:18 PM
At risk of being shot... Check Ebay. Do a search for yz400 flywheel. Most of the results you get will be the original flywheel. Every so often, you will see (pictures) a FW with 4 bolts on the outer flange of the FW, at 12 oclock, 3, 6, and 9. Bingo. You just found a FW with a $200 weight already attached.
I bought one for my YZ426 this way. I think I paid $70 for it (flywheel with weight installed). The YZ400 and the YZ426 use interchangeable flywheels. The WR series, as Gray mentioned, need both the flywheel AND stator, plus additional work.
  • ktmheinzee
Posted December 04, 2011 - 09:12 AM
So will I need to ground the pink wire if i'm not going to run any lights.
Posted December 04, 2011 - 02:50 PM
No, you'll need to do the pink wire mod as described in order for the bike to run at all with the WR stator.
  • ktmheinzee
Posted December 04, 2011 - 05:28 PM
Thanks for the help
  • Hot  36 replies
  • 10 replies
  • Hot  113 replies
  • On January 15, 2017
