which feeler gauge
4 replies to this topic
  • yamahasocal450
Posted September 27, 2003 - 07:24 PM
ok i think im going to expand my mechanical abilities to adjusting valves, but i see the only tool i need is the feeler gauge, so my question is what kind should i get, and do i need anything else like the valve spring compressors and stuff like that :D thanks guys i appreciate it :D :)
  • jasowiii
Posted September 27, 2003 - 08:32 PM
I just did mine for the first time.
If you choose only to adjust the lash you will not need to commpress the springs. If you need to adjust any you will have to pull your cams, I used a permanent marker to mark links on the timing chain and corresponding points on each sprocket so that it was easier to reassemble.
I used a real strong rare earth magnet to pull off each valve cap and get to the shims underneath, Be careful, they stick to the inside of the caps and I dropped one... If you intend on working on the seats or checking your springs you will need to compress the springs for disassembly. Use planty of "Engine Assembly" grease when you reinstall the cams and torque them properly before movement or you can score the bearing journals.
FYI 0.001" = 0.03937mm
Hope this helps, Good luck :)
  • holeshot426
Posted September 29, 2003 - 10:32 AM
Last I checked .001"=.0254mm.....
  • GrahamO
Posted September 29, 2003 - 10:45 AM
1mm = .03937"
.001" = .0254mm
  • jasowiii
Posted September 29, 2003 - 07:31 PM
You got it dave! :D
