07 YZ450 backfire
6 replies to this topic
  • mnichols
Posted December 01, 2011 - 06:35 PM
So I finally got my bike back together after replacing a stator and right side radiator. Bike has a major backfire going. Now I used some gas that was alittle older than I would have liked to put in it but I really wanted to see if it would start.
So could this backfire be from the old gas? Could my hot start be stuck open? It has a new plug.
Thanks for your input!
  • Yamiryder
Posted December 01, 2011 - 06:41 PM
check to make sure your exhaust is tight and not leaking.
  • mnichols
Posted December 01, 2011 - 07:15 PM
I'll check again, I did pull the pipe to change the oil filter. When I started it outside in the dark and it was idling the head pipe was glowing red. It did go back to normal after I took it up and down the street. Thanks
Posted December 01, 2011 - 09:32 PM
That's normal.
So I finally got my bike back together ...
Sounds like it sat for a while. You probably have a varnish deposit in the pilot jet making the bike run lean. And, yes. start with fresh fuel.
  • mnichols
Posted December 02, 2011 - 07:24 AM
Thanks everyone. I drained the tank and cleaned the carb while I was was waiting on parts so I'll start with the gas. If it does the same thing I'll pull the carb again... Wouldn't be the first time I didn't clean a carb good enough. Thanks
  • mnichols
Posted December 03, 2011 - 08:38 AM
So I replaced the gas with fresh 92 octane and still had the backfire. Brought it back in the garage to start the process of pulling the carb. Pulled the main and pilot (48), they looked good but I cleaned them again. Put it all back together and..... Still backfire on decel. Checked head pipe and it worked itself loose. Tighten that up and it sound better at idle but still had a backfire on decel when going up and down the street.
Could this be just a jetting issue at this point? Last time I rode it was in the 60's. When I've been testing after working on it after work it's been in the 30's and 40's. I'm at 4800' and it is getting cold.
Bike idles fine with choke on but a little rough with the choke off.
  • mnichols
Posted December 03, 2011 - 06:37 PM
When I put the carb back together I close the air screw all the way. Opened that up about 1 1/2 turns and ran much better
  • Hot  38 replies
  • 0 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  30 replies
