So I bought a 2006 CRF450R and took it out to the track. For the first half of a lap, it ran perfect :banana:, from idle to redline (under load) it ran perfect. At about half a lap, it started to bog when the throttle was opened past 1/8 throttle, as if it was out of gas, or another way to describe it is that it was as if the kill switch was being pressed. After letting the bike sit for a couple of minutes, I fired it back up and it worked great again for a few seconds, but then the same thing happened. It is VERY repeatable and didnt happen during practice (light riding) but did happen during the race (heavy loading).
I have completely gone through the carb and hoses to make sure the it's not a fuel delivery issue: everything checks out, no hoses are pinched, jets/ports are clean. After reading other posts on TT I believed it was the TPS. I replaced it (b/c after testing, I found that the old one was faulty and non-linear with resistance). Thinking that it was fixed, I entered an enduro race today, but had the same thing happen :banghead: It seems to definitely be an ignition problem. Again, from start the bike runs perfect, no issues at all, but as it is driven around the track (and warms up...) it bogs as if its out of fuel when I give it anything above 1/8 throttle. I can still drive it ONLY if I keep it under 1/8 throttle, but once I open it up it sputters and dies. Also, once it acts up, it will continuously bog until I shut off the bike and let it sit for a few minutes. But upon starting and riding a short time it happens again.
Any ideas? My next guess is that it is the coil or stator...? Please tell me there is someone out the that's had the same problems?!?! :thinking:
