2012 wr450
716 replies to this topic
  • trailhead2004
Posted May 24, 2012 - 01:23 PM
The frame is identical to the 2012 yz250f according to Yamaha.
Not quite "exactly" the same. The rear triangle is different for the WR to make room for the air filter and battery. If you look at the one of the sides of the frame, left I think, you will see where the mounting point is for the YZ250F, the tapped hole. Whereas the WR has a tab welded to the frame.
trailhead :cry:
  • supermega1
Posted May 24, 2012 - 02:05 PM
[Supermega1] The Comp ECU preloaded map is flat, all zeros. I found that out by "downloading" it from the ECU after I installed it. I just plugged in one of the basic maps on the sheet that comes with the ECU. one of the things I think is nice about the programmer is that you can store up to 9 preset maps.
Yeah I checked that with the programmer when I installed mine. But I am 99% sure its different (besides dirt rider said so :cry: ). From the things I've read to my experience with it after installing it. Just because its reading "zeros" in the programmer doesn't mean the default values that are programmed in the COMP ECU aren't different then the ones in the Stock ECU. Its just reading the new values as "zero" values or as the default values for the new ECU. Not to mention those "zeros" only represent "Fuel" and "Ignition" which are the only variables that can be changed in the ecu. The ecu has variables probably for at least 10 other things in it that are not adjustable which means they could be different from the stock ecu to the comp ecu.
When the bike was completely stock you could barely fire it up first try. Idle was lumpy and it was hesitant to rev loaded/unload
Pop the comp ECU in and it fires up first try every time, idle was smooth, and there was no hesitation to rev loaded/unloaded
That is without changing anything other then the ECU.
  • A X E
Posted May 24, 2012 - 07:50 PM
trailhead :cry:
That is the subframe not the frame.
  • A X E
Posted May 24, 2012 - 09:32 PM
So I just filled my tank back up and it took just less than 1.5 gallons to fill it back up. So to recap.....fuel light came on around 35 miles, I drove it 46 miles, and still had approximately 1/4 tank of fuel. That means it was getting about 30 mpg and should get around 60 miles to a tank. That was with the comp Ecu, map for the stock can with woods map, PMB exhaust insert, and a combo of moderately aggressive desert and highway riding.
That seems a little high but, I will take it all day if it is repeatable. YMMV.
  • CaocaoWR
Posted May 25, 2012 - 02:35 AM
Nobody wants to ride a choked dog
I have heard of "chocking the chicken", but I would have to plead ignorance about "chocking a dog". :cry:
Sorry for my bad English! :ride: Just want to express that the bike can run like crazy when twisting the throttle, but when ease off the throttle it hiccup.
So, anybody has the map that can works for Dr.D pipe? This is the very first 2012WR450 in here, and we have no dealer who can help set it up. :cry:
  • BFox
Posted May 25, 2012 - 04:02 AM
Sorry for my bad English! :cry: Just want to express that the bike can run like crazy when twisting the throttle, but when ease off the throttle it hiccup.
Thats OK.Your English is better than our Vietnamese.Your buddy needs to get the competition ECU that also comes with a shorter throttle stop screw and the YZ Power Tuner.The ECU comes with some baseline maps, The FMF exhaust map would probably be a good starting point for him. He is running premium fuel in it right?
  • CaocaoWR
Posted May 25, 2012 - 04:40 AM
Thanks for the advice!
The Comp. ECU and Power Tuner was ordered. We often use A95 gasoline, that's the best we can have here.
  • xcountryfreak
Posted May 25, 2012 - 05:07 PM
Has anyone noticed that the swingarm is from the 2011 WR? I don't understand why they would take a 2012 YZ250F frame and put a 450F engine in it and then take the cool new swingarm off, which is supposed to be lighter and flex better, and put old technology on that new frame? Is this new model just a strategy to get rid of some left over swingarms, engines and frames? The engine design is ancient, except for the FI. And the weight is over the top. I know some of you will never get the whole weight issue but my WR250 was 220lbs dry after spending lots of bucks on making it lighter and it felt really heavy. This thing is what 270lbs??? Do they really think that Whibbs is going to race one of these? Not unless they build a one-off 220 lb version just for him.
Yamaha could build the best off road bike in existence if they wanted to.
They don't. All they are concerned with is profits.They have lost touch with the passion of motorcycles. Hate to diss them, I ride and own nothing but yamahas, but its just nuts. It's almost as if American politicians have taken over Yamaha.
  • xcountryfreak
Posted May 25, 2012 - 06:17 PM
BTW - You guys who bought the 2012 WR450F, I'm just jealous. It really does look cool and I'll bet it's great in the woods. I wouldn't buy one to race, but for fun, it's probably one of the best. You could ride it, wash it and ride it again many times over before having to do any serious maintenance.
  • Bandit9
Posted May 25, 2012 - 07:05 PM
I agree. The same as taking six years to finally put the SSS fork on it. Like no shite, took 6 yrs to finally make that connection??? Really? Had that many open bath forks to get rid of?
Hydraulic clutch??? Why isn't this standard? What about the Auto Clutch?? Think they know how to do that after 30 yrs of quad trannys? Street Legal?
It's almost as if they don't really want to sell a bunch of bikes........
Build it and they will come.
Edited by Bandit9, May 25, 2012 - 07:09 PM.
  • BFox
Posted May 26, 2012 - 04:15 AM
Nice. A centrifugal clutch on a 450 dirt bike. You could mount the spare belt to the front fender too. Yammi engineers you listening???As for the juice clutch. Can be more of an ass pain than their worth at times.Had on several different 4T Huskies
  • Bandit9
Posted May 26, 2012 - 05:26 AM
No belt. Just a regular centrifical clutch like what they have on a Wolverine.
  • BFox
Posted May 26, 2012 - 05:46 AM
Would seem from further investigation that the means of transmitting power between the engine and transmission on a Wolverine is a CVT. Or a "BELT" driven between to centrifugal clutches.
  • YZEtc
Posted May 26, 2012 - 06:17 AM
Back in the day, ATVs from Yamaha and Honda that used some kind of automatic clutch actually used two clutches and no drive belts.
One clutch was mounted on the end of the crankshaft and was a typical centrifugal clutch with spring-loaded shoes that engaged an outside drum with a rise in crankshaft RPM.
The second was a pretty much normal-looking motorcycle multi-plate clutch mounted in the typical spot on the transmission main shaft, and that was disengaged via a shift shaft linkage whenever a shift was made.
That's why you can ride an old ATC-185S and pop the front wheel up by pressing down on the shift lever, reving the engine up a bit, and letting the shift lever back up.
Edited by YZEtc, May 26, 2012 - 06:21 AM.
  • BFox
Posted May 26, 2012 - 07:27 AM
Kind of like a chain saw
  • OUTERLIMITS
Posted May 26, 2012 - 09:24 AM
There is a reason that Yamaha did not mess with the "ancient" WR450 motor. It's plenty strong and probably the most reliable motor out there. They did something awfully right when they designed it and it has it's power right where it needs to be. Why mess with that?
  • Bandit9
Posted May 26, 2012 - 09:43 AM
This what I'm talking about.
Now I don't like Auto Clutches, but from a sales standpoint and judging by how many Rekluse are sold, they would sell a bunch of Wr's with that style clutch from the factory.
Edited by Bandit9, May 26, 2012 - 09:49 AM.
  • Bandit9
Posted May 26, 2012 - 09:44 AM
I agree, motor is fine. I never said anything about the power. I like the power just the way it is.
  • MANIAC998
Posted May 26, 2012 - 03:31 PM
The motor is fine, but a sixth gear in the tranny would increase bike sales off the chart!!!
Maniac
  • Krannie McKranface
Posted May 26, 2012 - 06:20 PM
Once again, the moderators have deleted my posts.
RIDICULOUS.
