Head gasket needs to be replaced once torqued?
6 replies to this topic
  • batmobil
Posted November 16, 2011 - 01:30 PM
Hi,
I have been working on a WR426F I just recently bought. The engine needed a total rebuild and I have changed all bearings, bought a big bore kit and a used head. After finishing torquing down the head I notice that I have managed to forget to install the cam chain guide that are to be mounted once the cylinder is installed and before the topend.:busted:
So my question to you is: Do I need to replace the head gasket when I unbolt the head to install the chain guide?
Thanks!
Batmobil
  • RasmusDK
Posted November 16, 2011 - 04:22 PM
The right thing would be a new one.Once i did something like you, and couldnt get a new one unless i wanted to wait 8 days, so used the old one. That is still running.. The gasket have much wear tho..
  • bg10459
Posted November 16, 2011 - 04:31 PM
I don't think it's a problem because the procedure in the manual calls for torquing the head down, then removing the bolts to apply more moly lube, then re-torquing the head. You haven't heat cycled anything yet, so you should be OK.
  • Stinger1133
Posted November 16, 2011 - 05:26 PM
I pulled my head and jug checking for wear and a noise on my YZ426 and bolted everything back together with same gaskets.:busted:( I do not recommend doing this.) I torqued everything to spec and bike is ok even after 4 weekends of fun. These gaskets are pretty tough. Again, even though I did it successfully, I dont recommend it. This is a weekend toy for me. If it went down, I would just ride my other toy till i fixed it.
  • Sknight
Posted November 16, 2011 - 05:57 PM
As said above since it hasn't been heat cycled it'll be fine. In fact mark your bolts before you loosen them, you'll see that they'll actually turn a little more before torquing down/after completing your angle reading. It used to be common to loosen and retorque head gaskets.
  • batmobil
Posted November 17, 2011 - 01:40 AM
Thanks, guys. I got feedback from seller of the big bore kit as well. He said, as several of you, as long as it hadn't been heat cycled yet I could reuse it.
Appreciate your help!
  • Joe ONeil
Posted July 07, 2015 - 09:49 AM
Old thread I know, but this is good news.  I notice some seepage around the head gasket after filling the fluids on my rebuild.. no heat cycle yet so I'm going to use the copper spray sealant and re-torque it.
