Help starting new 04 YZ450
3 replies to this topic
  • GGimbert
Posted September 24, 2003 - 04:22 PM
Picked up my friends new 04 tonight for him. Will not start. I have owned a 426 before & familiar with the old starting procedure but this is supposed to have auto compression release. I have kicked till blue, changed plug & kicked till blue again. There is gas in tank. What am I missing?
Anyone else have this problem?
Thanks for any help.
  • bayareathumper
Posted September 24, 2003 - 04:37 PM
did you try turning the idle speed adjustment knob clockwise a turn or two?
new ones can just be a bear to start, my 01 YZ426 was like you describe and then decided to start
good luck
  • lipskid
Posted September 24, 2003 - 05:25 PM
Ummm... did you make sure the it's turned "on". :)(button behind right side of headlight, red light indicates "on").
Mine needs when cold- Choke on- 3 to 4 twists of throttle- then no throttle while kicking. Usually starts 1st or 2nd try. :D
  • lipskid
Posted September 24, 2003 - 05:28 PM
oops, sorry, YZ, my bad. :)
