Overheating 390 FE
Posted 12 November 2011 - 03:54 PM
overheating problem is to change the exhaust, this will allow free flow as the stock exhaust is the main
problem for the overheating issue, any comments on this or advice?
Posted 12 November 2011 - 05:06 PM
When you get a chance, do a 'Search' on ThumperTalk and www.husaberg.org. All bikes will overheat in slow going conditions. The first and perhaps best remedy to start with is a radiator fan.
Posted 12 November 2011 - 05:47 PM
An aftermarket exhaust may help as well, but the 2011 shouldn't be too bad. The 2009 and some 2010 had really restrictive exhausts, but some were the KTM exhaust that isn't so bad.
Also find out what map is installed in the ECU. The stock map runs lean. Have your dealer load the competition map.
Also use injector cleaner and stabilizer in your fuel. These bikes seem really sensitive to fuel problems. There have been lots of faulty fuel pumps and plugged injectors.
Mine was running really hot one day (on a cool day). I replaced the injector and it has run fine ever since. I was messing with the fuel lines and probably got some crud in there.
A lot of people install some heat reflective tape on the bottom of the tank to help keep the fuel from boiling too easily. And some wrap or ceramic coat the mid pipe.
I finally added a temperature gauge to mine. It usually runs around 210 degrees F or less. If it gets above that, it is a warning that perhaps I need to clean the injector or something.
There is lots more data on Husaberg.org and the Husaberg forum in KTMtalk.com.
Posted 12 November 2011 - 08:27 PM
And after market muffler will allow the motor to run much cooler too.
Posted 15 November 2011 - 05:34 PM
Same problem, fixed. Cooling fans, Heat wrap for tank, Evans coolant.
Now it runs cooler than the DRZ 400 E, my Buddy is borrowing it for the races and rides and it will overheat first. I still overheated stuck on a lose gravel hill climb and not moving. When the red light comes on, shut it down because it is warning you.
I race the HGP Hare Scrambles in US southern MO and on some of the most technical and tight woods racing around.
Posted 15 November 2011 - 07:50 PM
Posted 17 November 2011 - 08:47 PM
Another worthwhile mod to thoroughly beat it into the ground - change out the fan thermo switch for a lower temp one. I have a trail tech temp gauge on my bike and the stock fan switch is set to trip when the coolant temp at the bottom of the rad (the coolest area) reaches 210F. My temp gauge read 223F when the fan tripped (hot water temp coming off the head) - a bit warm for my tastes. The high temp switch is a carryover from the KTMs, which have a weak charging system. Excess fan use kills the battery in those bikes.
Changed out the switch for one meant for a 1984 BMW 325i ($18 at NAPA) and now the fan trips at 203F and turns off at 193F, again measured at the hottest water exiting the head. The fan runs more, but unlike the KTMs, the Bergs with their FI have a stout stator (211 watts output). They could run the fan 100% of the time and the battery would be fine. I say let the fan run. Feel free to add heated grips too if you like
A pic of my temp gauge setup.
If you leave the rad cap on and are quick, you can swap out the fan switch with minimal coolant spillage.
Posted 17 November 2011 - 10:27 PM
I'll order that BMW part!
For mounting, I would suggest laying the bike over on its left side.
Posted 18 November 2011 - 06:42 AM
I still have the stock thermostat. My max temperature is usually between 210 and 230 after a days riding. The day mine was running poorly, it was much, much hotter than that. I didn't have the temp gauge at that time, but I could tell the bike was radiating a ton of heat. After cleaning the fuel system it has run perfectly since.
Posted 19 November 2011 - 10:13 AM
Posted 19 November 2011 - 11:15 AM
zabe45 said:
Mine is a 2010 FE450.
I don't think there were many significant changes that would impact heat between 2009, 2010, and 2011 with the exception of the exhaust can. I don't know when the change occurred, but some folks have the really restrictive can while others (like me) have the more free flowing one. Plus there were those built with the faulty fuel pump.
Posted 19 November 2011 - 11:46 AM
zabe45 said:
They are all the same as far as the cooling system goes, and in most other respects that matter.
Posted 24 November 2011 - 09:50 AM
Found this on dirt Bike world talk forum. Going to check this ot today.
Discovered today the fuel is coming from the tank breather.Seems ok with under half a tank of fuel but when full the little ball thingy in the cap is not shutting off and at only 45deg it pisses out,Pulled it to bits thinking it might be blocked but all looks good inside there.New cap would be shit loads so looking for alternative guys??...Does the little rubber dongger set up i have seen on few bikes have a one way valve in it or is there something else i should look at?
__________________
FE-390 2011
Edited by old man dave 59, 24 November 2011 - 10:52 AM.
Posted 24 November 2011 - 06:23 PM
I recently put mine back in. I noticed some fuel weeping from the hose at the one-way valve when the bike was hot, but otherwise didn't notice any difference. But you wouldn't want to open the cap when it is under pressure or you could get a face full of hot fuel.
Posted 30 December 2011 - 11:21 AM
http://www.fuel-test..._water_gas.html
You could plug your breather line before you store the bike for some time.
Posted 30 December 2011 - 04:48 PM
http://www.napaonlin...AND(P_RecType:A) Altom Imports, part ATM 1435033.
New years bonus! Link below to the fuel filter every fuel injected KTM product should have, as KTM seems to be pathetically spastic on this issue
http://www.parkeryam...outlanders.aspx
Can-Am quad fuel filter part number 709000100. Spend the $13.25. Save a giant headache
