inline fuel filter ?
I tried running a larger capacity one before. It was the type with the brass filter and clear plastic case so you could view the element. It worked just fine, didn't restrict flow one bit, but it only lasted one ride. I was sloppy with the install and it vibrated it self to death on the cylinder base nut. I removed it and haven't ran one since.
As someone else said... just remove the petcock and clean the screen in the tank... that's all you should need.
I run a fuel filter on most of my bikes, especially 2 strokers so I can visibly see that I drained the carb before letting the bike sit. Its also easy to see if your bike died due to being out of gas. The problem with relying solely on the pet cock strainer is they fail with age themselves, and very rarely does anyone check their condition. The harsher the additives or fuel you run the faster they deteriorate. A new filter every season or every other season is good insurance as they are very cheap.
Always after picking up dirt in both carb on my RZ years ago.It's the first thing I put on every bike I get.The fuel tank strainer isn't fine enough to pick up particles that will bugger up your carb.Most bike shops sell the triangle shaped filters,about an inch long with what looks like a perforated stone inside.Cheap,tough,the media won't disintegrate and lasts a long time.I change mine every year.Cheap insurance and will in no way restrict fuel flow.I've never had a dirt related carb issue since the RZ in '89.
Normally on our YZs we don't run fuel filters. The mesh screen on the petcock seems to be all we need. :busted:
But I did a lot of research on small, effective fuel filters for our old streetbike, and found these;
http://www.obyamaha.com/eshopprod_cat_6539-10275-32664_product_970413_keyword_fuel+AND+filter.VISU-FILTER174_HIGH_FLOW__.htm
Basically, it is the smallest, best-filtering, highest-flowing fuel filter you can buy at a reasonable price.
Made by VisuFilter (or ITW Fastex or Plastisonics), it is a high flow/high capacity design with 8 square inches of polymerized paper filter area in a sonically welded, high-impact nylon housing.
It has a gravity flow rate of 7.6 gallons per hour compared to 2 to 4.5 gph of a typical in-line filter. Suitable for gasoline or gasohol. Made in the USA!
There are a few different part numbers for the filter;
12-1564 (or 861C) fits ¼” hose
12-1566 (or 862C) fits 5/16” hose
Prices are around $3.75.
  • Like 2
these type of filters are good. thats what i got. they come in different micron levels though, be aware of that. alittle bulky and may not fit on some bikes however. the bronze cone type work good and fit better in tight places
We have the 861C in stock:
http://shop.thumpertalk.com/ProductDetails.asp?ProductCode=PU_861C
They are only sold in cards of "20" and we ordered too many so we have been sitting on 27 for a while now. Ill give them to you for a buck a peice until they are gone.
Here is the closeout link:
http://shop.thumpertalk.com/product_p/closeout_pu_861c.htm
Those are for 1/4" hose. The fuel line on the YZ125 and YZ250 are 5/16" i.d.
Edited by FGR01
  • 3 years later...
