97 rm 125 clutch adjustment issues
7 replies to this topic
  • ridervt
Posted November 09, 2011 - 04:39 PM
I just put a new clutch kit and cable into the bike and I can not get it adjusted properly. No matter where I adjust it to it lurches when I shift into gear. Why?
  • tmacoo4
Posted November 09, 2011 - 06:32 PM
If it keeps "lurching" then check your clutch basket for grooves and if you have grooves just file them down.
  • Bhavesh
Posted November 12, 2011 - 12:48 AM
learn how to search the intarwebs more better
  • jamesrm125
Posted December 23, 2011 - 06:51 PM
mine was doing the same from grooving
i went in today and filed mine down (its cheaper than 200+new one)
now it works like brand new
i also sanded the filed edges down too smooth the filled edges down
look up videos on you tube to pull apart and put back together properly
good luck
  • clintsmx
Posted December 25, 2011 - 04:49 PM
filing the basket is ok but if you plan on keeping the bike you will need a new basket in time.
  • ridervt
Posted December 27, 2011 - 01:35 PM
I determined that the basket is ok...sounds like it may be a bent shift fork. Saving my pennies to get it done beforespring
  • Tailender
Posted December 27, 2011 - 02:01 PM
A bent shift fork would not make it lurch forward. That only controls the gears position/what gear your in. There is something dragging in your clutch to cause the lurch. Using the correct oil? Soak clutch before install? You could try a lighter oil maybe. My bike does this until it gets warmed up then no lurching.
  • Husa your Daddy?
Posted December 29, 2011 - 04:05 AM
Typical Suzuki issues. Check your basket and hub for notching and burrs. Automotive ATF type F works well in Suzuki's 'less than desirable' clutch components. And as said, soaking your friction plates beforehand is a good idea.
We've still got a 98 125 that sits around if my boys want to go riding with me. It's been a good 10 years now, but I remember reading somewhere that taking the clutches push-rod and filing the squared end (that goes inward) to a more rounded shape will help with your issue... don't know why, but I did it and it helped.
Our 98 has a Hinson basket, a 'like new' OEM hub, good OEM frictions, modified push-rod, ATF, adjusted to a minimal amount of free-play at the lever/perch, and it still drags somewhat, just gotta live with it.
