pastrana fmx bars
18 replies to this topic
  • The Hopper Show
Posted November 04, 2011 - 09:33 PM
anyone run them on there wr? i am 6'3" tall, and ride trails exclusivley. i have very long legs, and find myself bent over at the waist alot when standing. this is uncomfortable for me. the pro taper countour pastrana fmx bars have a 120mm rise, and are only 30.5" wide. this sounds appealing, as there are trees here in the great northwest. my problem, though, is i have the older style 7/8" yami tripple clamps which means i would need to run a bar adapter to run these bars. would the combination of the 7/8" to 1 1/8" pro taper bar adapters, and the added height of the pastrana fmx bend bars give me too much height and make it uncomfortable the other way? what would this do for controllability of the bike? and are bar adapters safe to use? or are they considered to be a band aid like adding wheel spacers to your hubs on a truck to get your oversize tires to fit?
also, with the taller rise, how would full wrap hand guards such as cycra's fit these bars?
  • climaxx dirtbikes
Posted November 05, 2011 - 04:03 AM
Good question. I am awaiting an answer as well. I'm 6'5 with stock 1 1/8" bars and 1.5 inch risers. They help but dont solve the problem.
  • Krannie McKranface
Posted November 05, 2011 - 09:30 PM
I am 6'4" and have tried multiple combinations of bar risers on multiple bikes.
From no rise (using stock ProTaper IC3-90 85mm rise)
To KX High (20mm more rise) and BRP submount (+26mm more rise)
To RM Mid (18mm more rise) and Roxrisers (26mm more rise up AND foward)
To 3/4" (1 1/8" adaptor) risers with Pro taper CR High bend and RM Mid
To Custom Triple Clamp/risers with Pro Taper CR High bend
...and all the different adaptor/riser combinations.....
http://t2.gstatic.co...oq6Qg0l_BAaFYJb
...and the conclusion I came down to was this:
A 1" rise from stock is just barely enough to ride all day, and still have great cornering feel and center of gravity when sitting down.
A 2" rise from stock is more comfortable all day, but steering precision is lower, and less comfortable when seated. The bars unfortunately get closer as they get higher because of the angle of the triple clamp. Moving the bars forward 5mm when you go up helps a lot but usually requires custom triple clamps to do so.
Any thing higher with the bars requires a much higher seat ( which I still use and love, but with only 1" bar rise)....but the higher bars don't work unless you stand all day. Sitting down they are like chopper ape hanger bars.
  • The Hopper Show
Posted November 06, 2011 - 07:53 PM
thanks for the great reply! so all that said...what was your favorite combo? :busted:
Posted November 07, 2011 - 07:04 AM
Ha! I was waiting for that!
KX High bend Protaper with approx 1" of rise, and a Guts Racing Tall/Medium soft seat kit, and Fastway Low-boy footpegs.
On the KX I raised the seat another 1" because the pegs are higher up and more forward than on my CRF or WR.
Edited by Krannie, November 07, 2011 - 05:48 PM.
  • climaxx dirtbikes
Posted November 07, 2011 - 05:03 PM
Great posts! Thanks for the pics too! Nice Bikes!!
Posted November 07, 2011 - 05:49 PM
Edit:
KX High + 1" risers/adaptors,
  • gsa102
Posted November 08, 2011 - 09:26 AM
I am 6' 2" and use +1" risers with the stock bars; any more would be too much.
I have a guts racing tall/soft seat. I should have got the medium foam as it has broken in to be about the same ride height as the stock seat. But it is very comfy.
I am going to check out the low-boy pegs. The seat/peg combo is still a little tight.
  • SJMC_DON
Posted November 10, 2011 - 04:58 PM
I ran the combo as you have described on my 04' (riser /adapters plus the Pastrana FMX Pro Taper contour) and I thought it was perfect. (I am 6'3" and grew up riding Reiter :busted:) Be careful though because you will be at about the extent of your throttle cable's reach, it will work though.
On my newer bikes I have gone with BRP sub mount / Scotts stabilizer and stock bars, (could be a little higher in my opinion) Might check out the KX Hi Bend too, thats a good rise but should be cut down in width a little bit for woods.
Good luck!
  • The Hopper Show
Posted November 10, 2011 - 05:52 PM
what riser/adapter did you use with your pastrana bars? and on what bike?
did you feel the 7/8" to 1 1/8" adapter to be stable and safe?
  • SJMC_DON
Posted November 11, 2011 - 08:32 AM
It was an 04' WR450 and I think they were the APPLIED risers or they might have been the ProTaper???
They never felt anything but solid and that bike had almost two full season of Harescrambles on it...
I think tjhis is the only pic that shows the bar height
  • The Hopper Show
Posted November 11, 2011 - 04:40 PM
that does not look to bad actually! how does it handle like that at higher speeds? say desert riding? and how much total rise did the riser itself give you? like an inch or so? and then the bars on top of that? i am trying to find the shortest possible riser to use with the pastrana bars, so my bars are not SIGNIFICANTLY higher if that makes sense?
  • The Hopper Show
Posted November 11, 2011 - 04:41 PM
and any fear of crashing and breaking the yamaha top clamp having the bar risers? will the tripple clamp break using bar risers the way it is machined into the clamp, unlike say, a honda top clamp?
  • The Hopper Show
Posted November 11, 2011 - 04:46 PM
trying to find the specs on the factory yamaha bars and can't. does anyone know the rise of factory bars in mm? trying to figure out the diff in rise from factory rise to pastrana rise.
Posted November 11, 2011 - 04:50 PM
The adaptors are fine. ProTaper makes a Black one, or Moose Racing makes sever sizes in silver. Solid as a Rock.
  • The Hopper Show
Posted November 11, 2011 - 04:51 PM
And SJMC_DON, i would love to hear more about the setup on that '04 wr you just posted. i see alot of aftermarket. would like to know what you ran, what you thought worked, what didn't, and if you did things you thought did not matter much. i can see my bike going alot in that direction, and would love some insider info. obviously we ride alot of the same terrain. you can pm me if you want. thank you sir!
  • The Hopper Show
Posted November 11, 2011 - 04:52 PM
The adaptors are fine...Solid as a Rock.
thats what i needed to know!
  • The Hopper Show
Posted November 18, 2011 - 06:38 PM
  • Stretch44
Posted February 12, 2013 - 09:55 AM
What handguards are you running in this picture? I'm looking for some that fit my pastrana fmx bend bars...
