KX250f 05, blown head gasket
4 replies to this topic
  • Gerard3312
Posted October 23, 2011 - 10:16 PM
i have a problem, the head gasket on my KX is blown, the bike wasn't ridding when i realized it, so i dont think it overheated. but my exhaust was filled with coolant, what do i have to replace eccept the head to get it running again?? and do you think the packing in my exhaust is damaged from the coolant?
  • vallibirgiss
Posted October 24, 2011 - 11:10 AM
Somehow i dont think that a blown head gasket would cause the exhaust to fill with coolant ....But i may be wrong but my guess is that your Cylender Head is Cracked
First of all i would Tear the top end down and inspect everything.
  • Gerard3312
Posted October 25, 2011 - 12:04 AM
What should I be looking out for?
  • vallibirgiss
Posted October 25, 2011 - 05:54 AM
For cracks or any damage. Take a flashlight and put it in the water jacket in the head and see if you can see any damage ..
But as i said im not 100% that a cracked head is a problem i would try to ask D-K or Primal they are Pro's
  • D-K
Posted October 25, 2011 - 11:49 AM
A blown head gasket can let the coolant get into the combustion chamber, but it will not be much, at least to begin with.
And it will do it while running when the pressure rises. When cooled back down the water is under no pressure and it will be very little entering the combustion chamber. It will be smoking white when started cold, then it lessens.
If the exhaust fills up with coolant while the bike is sitting, there must be a big crack in the head. I really can´t imagine anything else being the problem.
As mr. Birgisson said, you need to take the head off and inspect the parts. Post pics if you can.
I am looking to buy a kx250 and just need some info on the pros and cons of a 2006 kx250f by Nitro_
Dirt Bike   Make / Model Specific   Kawasaki   KX250F
  • 6 replies
Riding in the Snow by Ripping_RobMX
  • 3 replies
Winter Wheelies! by Ripping_RobMX
  • 0 replies
2 Stroke Maintence by 3262bk
Dirt Bike   Make / Model Specific   Suzuki   Suzuki 2-Stroke
  • Hot  33 replies
Youtube Channels by CodyR
  • Hot  284 replies
