wiring a fan to a wr450f through ignition
4 replies to this topic
  • wr450man
Posted October 22, 2011 - 05:29 PM
I just purchased a 4" spal fan.
I want to wire it to my 2006 wr450f (has a baja kit with key).
I would like the fan to work only when the engine is running (through the ignition )
Has anyone done this type of wiring? Which color wires did you connect to?
I intend to use a switch to turn the fan on and off, but I want it to be working only if the engine is running.
  • alwayson1wheel
Posted October 25, 2011 - 07:22 AM
not sure on all of the wires as i just recently got my wr, but i would atleast power it through a relay so it wouldnt burn it up. i wouldnt just run it off of the ignition.
  • GuyGraham
Posted October 25, 2011 - 10:24 AM
you want a switched live, which are brown on Yamaha's
  • wr450man
Posted October 25, 2011 - 01:20 PM
perfect, thanks!
  • ur2silly
Posted October 26, 2011 - 04:54 PM
Here is what I did. Even though the relay I bought ended up being crap, the concept would be the same with a quality relay. Hope this helps
