GYTR shuts down
6 replies to this topic
  • Pedro Cutillas
Posted October 22, 2011 - 03:12 PM
Hi folks, my GYTR shuts down when i connected it to the bike, its a 2011 YZ450F, any idea?
thx
-p
  • dwerthones
Posted October 22, 2011 - 03:24 PM
GYTR I would assume your referring to the tuner? Try replacing batteries
  • dalonar
Posted October 22, 2011 - 03:35 PM
are you talking about when you plug it in with the tuner on it will shut off? Just hit the power button again?
  • HRC
Posted October 23, 2011 - 12:36 AM
Change batteries !
  • tech24
Posted October 23, 2011 - 05:44 AM
mine does the same thing. Put new batteries in it...does the same thing. Haven't used it for a while. They do wierd things with weak batteries. I just plug it in and start the bike. If you need to load a map, start the bike then shut it off, mine stays on then.
  • Pedro Cutillas
Posted October 23, 2011 - 01:06 PM
yes the tuner, yes it shuts down when i connect and it won't start when connected, otherwise it it starts (the tuner) just fine, will try with the bike on, seems bit weird
  • jeffdelio
Posted October 25, 2011 - 06:51 PM
I do know that on my bike with the Power Commander 5 installed, when attempting to change the timing map with the factory tuner it would not work. It would shut down as you described. So if you have a PCV that may be your problem. Disconnect all the PCV connectors and re-connected factory harness, tool connects and works fine? Possible CAN bus issue, power supply issue, I dont know?? I wish Dyno Jet would make a Ignition module for the 450F that would interface with the Fuel module.
  • Hot  47 replies
  • Hot  50 replies
  • On January 15, 2017
  • 10 replies
