Help Please: Bike bogging when throttled up
6 replies to this topic
  • doubld250
Posted October 21, 2011 - 03:06 PM
I have a nearly new 09 WR450F with 3 rides on it, it has a powerbomb and a power core TI. It has set up for a few months, gas smells fine it starts and idles fine but when I twist the throttle it bogs And will not run, if I leave the choke on it's a little better but still it will not rev up much. Any suggestions?
  • Krannie McKranface
Posted October 21, 2011 - 03:48 PM
Sounds like a clogged acclerator pump nozzle or mainjet.
If a slow roll-on throttle is fine, but a quick whack gives you a bog that you never had before, you either have a rotted accelerator pump diaphram, or you have a clogged accelerator pump nozzle.
If any attempt and turning the throttle gives you a bog, you have a fuel delivery problem. Start with the tank vent, then the tank fuel line, then the carb inlet, then the mainjet.
  • GuyGraham
Posted October 22, 2011 - 01:24 AM
I agree
if all else fails, take carb off bike and hang it at the side of the bike
look down the venturi and confirm you get a squirt of fuel
it should be approx 1 sec duration on a full throttle opening, and should not hit the slide
Use a digital camera to film it to confirm
you want the squirt to just miss the slide as it lifts
  • doubld250
Posted October 22, 2011 - 03:26 AM
Thanks for the advice gents, I'll check those things and hopefully get her up and running soon.
Posted October 22, 2011 - 03:18 PM
You don't need to remove the carb. Just lift the subframe and watch it 'squirt'.
  • GuyGraham
Posted October 23, 2011 - 08:44 AM
removing it stops it flooding the engine plus you get better film clip from a digital camera due to the venturi being lit by daylight rather than being in darkness due to still being fitted to engine
takes a few goes to get a good film clip
yes, if just to confirm it working then no need to remove
  • YamaLink
Posted October 24, 2011 - 05:13 AM
Fingers crossed it is the simple main jet. While you're in there make sure the pilot isn't clogged.
