Damaged Cylinder - usable?
4 replies to this topic
  • ACM
Posted October 21, 2011 - 07:29 AM
I chewed a valve and have acquired a 2007 used top end for my 2009YZ450F.
The new-to-me cylinder shows some signs of damage, but I'm not sure how bad it is.
Because of where I'm located, it will probably be easier to get a new cylinder than to get this one sent to be fixed, so it's really a question of whether I can get away with using it as is.
Essentially there's 5 marks (3 quite deep) about 5mm from the top of the cylinder. I'm hoping that because they're so high up it won't be a problem, but they are quite deep. See picture attached.
Thanks for any advice you can give.
Al
Posted October 21, 2011 - 08:31 AM
I don't like the looks of that very much. The scuffing/wear to the left of the triangle dings that runs clear to the top doesn't look good either, nor does the smaller ding farther right that's in the ring sweep.
I think I'd fix or replace it.
  • Ricks426
Posted October 21, 2011 - 02:34 PM
how much is it to get a cylinder shipped out and repaired? You can get a brand new jug from cheap cycle parts for $425.00
Posted October 21, 2011 - 05:09 PM
Did you look up a 426? The YZ450 cylinder is $315 from TT OEM.
  • BMuu
Posted October 21, 2011 - 06:11 PM
It's hard to tell from the pics but I would say if the rings pass over the damage I wouldn't want to use it.
  • Hot  30 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
  • 5 replies
