crf 450 carb tuning 2003
7 replies to this topic
  • ollacolla13
Posted October 20, 2011 - 08:54 PM
having problem tuning my carb... yes i have read the manual.. the jets are right, valves are good.. still having trouble starting... needl is third from the bottom and pilot air screw is 1 3/4 turns out... and don't know about the air screw but it was turned way out... thats how i tuned it to low down the idle when i got it started... will start fine when its hot... in the manual it says 5th position for the needle and idk if its from the top or bottom... please help a little thanks
  • fxrs
Posted October 21, 2011 - 02:29 AM
are you using full choke and 3 twist of throttle
  • tjg53
Posted October 21, 2011 - 03:48 PM
Your poilt jet mite be getting clogged. Try a new one , and see how it acts. Over time they do get clogged with varnish.
  • 450XJimDirt
Posted October 21, 2011 - 09:20 PM
I am gonna agree with tjg53 , your pilot jet is clogged , thank the Ethanol for that
If you have the proper jets for your altitude , and you read the manual and set everything to the recommended settings , then its either old/bad gas , or your pilot jet is clogged
  • ollacolla13
Posted October 22, 2011 - 08:49 AM
in the manual it says for the needle position to be on the 5th spot... does it meet the 5th position from the bottom or top?
  • fxrs
Posted October 22, 2011 - 09:08 AM
i would say from the top because it richens fuel you move the clip down
  • skthom2320
Posted October 22, 2011 - 12:04 PM
Needle clip position is counted top down. +1 on the recommendation to just switch out the pilot. That is a classic symptom for a clogged pilot (or fuel screw too far in).
BTW - there is no air screw. The fuel screw on a FCR carb is letting in more or less fuel in the pilot circuit , not air.
  • ollacolla13
Posted October 23, 2011 - 08:07 AM
my bad i meant fuel screw... i'll try a new pilot and see whats going on with that...
02 crf450r smoking after rebuild by bigg_stevee
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  43 replies
2008 CRF450r JB Weld on Crankcase by Sternzy
  • Hot  70 replies
Honda CRF450R 2017 by Chris.GVS
Honda CRF450R 2017
  • 0 reviews
Low compression J & E piston 2014 CRF450R by stroker
  • Hot  29 replies
CRF that has been sitting for 6 or 7 years, is that safe to buy? by deanevo
  • Hot  36 replies
