torque specs
1 reply to this topic
  • big babe
Posted October 20, 2011 - 04:59 PM
Help? need torque specs for a 99 wr 400 need head bolt specs. doing a base gasket for a friend. Any help would be great. Thanks
  • bg10459
Posted October 21, 2011 - 04:43 PM
Here's the procedure for my 03 WR450. Yours cant be too far off:
Clean threads and apply moly disulfide grease (assy. lube). Torque to 22 ft lbs.
Remove bolts, re-apply assy. lube, torque to 14 ft lbs.
Tighten each bolt 90 degrees and then again another 90 degrees each, for a total of 180 degrees past 14 ft lbs.
