oil from around push lever assy?
4 replies to this topic
  • atomic410
Posted October 18, 2011 - 10:47 AM
I replaced the seal which made it go from a gushing amount of oil to a trickle. do the push lever assy's wear out with the seals? It's an 06 yz450f. how common is that? maybe the new seal is bad? I have about 3 years of supermoto racing on it and this is the 1st time its ever had any kind of engine problem. replace the push lever as well?
Posted October 18, 2011 - 02:14 PM
The seal could be damaged, improperly installed, etc. The bearing below the seal could have loosened up also, so check that.
  • atomic410
Posted October 31, 2011 - 11:22 AM
how does that bearing come out?
Posted October 31, 2011 - 01:06 PM
From the top with a blind bearing puller.
  • atomic410
Posted November 01, 2011 - 06:33 AM
thank you. the book doesn't say. i also found a small crack in this area. i want to see how deep it goes. anyone have any experience with jb weld in this area? it take about 5-10 min to pool enough oil to make a drip. tells you how small the crack is.
