Air Filter Cleaning Tips??
5 replies to this topic
  • eBayThumper
Posted July 07, 2001 - 01:56 PM
Hey All,
What do you recommend for cleaning the air filter? I have some 'filter cleaner' but have heard other opinions in the past. Can't you just use mild detergent? Also, do you have to use grease at the outer edge/seal? Or can it just be the spray on filter oil?
Thanks as always!
  • dhvann
Posted July 07, 2001 - 02:09 PM
I use brake parts cleaner to clean it out, and use a thin film of grease to seal it. I dont know if this the right way to do it, but it seems to work.
  • MikeOK
Posted July 07, 2001 - 02:59 PM
First use mineral spirits to get the big gunk out, then any dish detergent to get the rest out. I always put grease on the seal too. I use the same stuff I put under fork dust seals- white lithium grease.
  • yzernie
Posted July 07, 2001 - 07:34 PM
I like to use the No Toil system. I put some warm water in the garage sink with just a little dish soap. They come out as clean as if I used chemicals.
You do not have to grease the seal but it is added insurance. Just a light coat of any waterproof or good quality grease.
  • #1_Hit-man
Posted July 08, 2001 - 03:34 AM
PJ1 airfilter cleaner, soap & water to finish. Pro-seal in place of grease, works great. ~Hit-man~
00'YZ426F 00'XR50R LATER DAYS!!!
  • sirthumpalot
Posted July 14, 2001 - 11:20 AM
I've tried both dish detergent and air filter cleaner and in my experience the air filter cleaner does a much much better job at disolving the air filter oil. Kinda pricy, but makes the job much easier. I have not tried other chemicals or detergents..
Need help by Goforaride
  • Hot  68 replies
  • Hot  491 replies
  • Hot  79 replies
  • 0 replies
