YZ250 crankcase/clutch cover replacement?
6 replies to this topic
  • YZ250Tractor
Posted October 07, 2011 - 04:06 PM
I need an aftermarket replacement for the cover as i got quoted a ridiculous amount for the OEM part. Do you guys know of any place that does them? I live in New Zealand so it would have to be cheap enough shipping. Thanks.
  • tim512
Posted October 07, 2011 - 04:57 PM
AFAIK there isn't an aftermarket option.
You could try and find something on ebay though, or post a wanted ad up in your local second hand classifieds. If someone has a blown up engine they may part with it for cheap.
  • NP4M
Posted October 07, 2011 - 08:16 PM
Rekluse offers one. It is slightly deeper to accomodate the taller stack needed with their components, but that can be offset with a spacer behind the rear break lever.
http://rekluse.mybig...over-Black.html
Not sure what cheap is to you, but check it out.
  • arnego2
Posted October 08, 2011 - 04:18 AM
Hinson offers one too but even more expensive than the OEM, how about ebay?
  • GMO397
Posted October 08, 2011 - 07:25 AM
Boyesen has a clutch cover.
Are you looking for the entire right side outer case, or just the clutch cover.
If you're looking for the entire right side outer case, I've never seen an aftermarket one. Find a used ebay one.
Clutch cover: Many companies make one, should be able to buy for less than 100$ (US).
  • YZ250Tractor
Posted October 09, 2011 - 03:24 AM
I bought one on ebay for $30 USD used. Better than paying heaps for the new one lol!
  • pentaxis
Posted May 23, 2012 - 10:48 AM
Which years will fit the same part for the outer clutch cover? I have a 2003 and it needs replaced.
Hero Dirt in the High Desert by 2strokeYardSale
06 YZ125 Oil Drain Plug Hole Stripped by Just Zach
  • 9 replies
3 points of Spooge by CaptainKnobby
  • Hot  60 replies
Yamaha YZ85 2017 by Chris.GVS
Yamaha YZ85 2017
  • 0 reviews
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
