ringnut wrench
5 replies to this topic
  • sirthumpalot
Posted July 05, 2001 - 08:07 AM
All,
Where did you guys find the ringnut wrench required for tightening the stearing stem bearings? Did anyone purchase this from the dealer, or have you all found a substitute tool to take its place?
Thanks!
  • MotoStyle
Posted July 05, 2001 - 10:41 AM
SirT,
I use the neanderthal method. A hammer and a flat blade screwdriver. Since the ring doesn't have to be very tight due to the fact that the headset tightens when you torque the top triple clamp nut, no reason for a special tool. If it needs to be slightly tighter, I back the headset nut off (making sure that the top fork tube clamps are defintely loose - Last thing you tighten up) and just tap the ring in whichever direction you need it to go. Hope this helps.
  • flyinguitars
Posted July 05, 2001 - 11:04 AM
Would this help? http://www.harborfre...temnumber=41243
Mike
  • yzernie
Posted July 05, 2001 - 08:15 PM
I did not know there was any other way!!!! :)
Ernie
  • sirthumpalot
Posted July 06, 2001 - 02:56 AM
Thanks everyone for your replies.
flyinguitars, that set of wrenches would be perfect with the exception that I would like to be able to connect it to my torque wrench. The manual mentions something like first torquing it to 34nm, then back off one turn, then torque to 7nm (don't quote me on the numbers as I'm going from memory but this is the basic idea). Thanks for the ideas though, I may end up with those if I cannot find the other type. :)
  • Thumper448
Posted July 06, 2001 - 06:06 AM
SirThumpalot,
You can purchase the Yamaha wrench from the dealer with the capability of attaching a torque wrench. Be sure to keep the wrench perpendicular to the torque wrench. As I recall the tool was not very expensive.
Stace
Pretty fly for a fat guy!
2001 YZ426 in the garage
2002 CR450F in October :)
  • 5 replies
  • Hot  38 replies
  • 10 replies
  • Hot  47 replies
