Using oil, crack case vent problem
1 reply to this topic
  • coxr650l
Posted October 02, 2011 - 06:05 AM
I have on 09 WR450 with about 6K miles. Recently it has started using oil anytime I am on the Hwy crusing at 55-65, even if for only 5-10 miles. It seems pretty sporatic though.
Several people have said it may be a problem with the crank case vent becasue it only uses oil at constant RPM. I can go to the track or trail and bounce it off the rev limiter all day and it will not use a drop.
Yesterday I started looking at the crank case vent tubes and noticed when i disconect them I can blow air through all of them except the one that goes into the air box. From the air box side I cant get air to flow in either direction.
Is this normal? Is there any kind of check valve that may be causing the crankcase to pressurize?
Thanks
  • GuyGraham
Posted October 02, 2011 - 08:41 AM
all the tubes should be free flowing - there is no check valve or anything like that AFAIK
Poke a wire or something up the blocked one and see what comes out
Can you feel the blockage if you compress the tube and slide your finger along it?
