How much oil does my 426 take
7 replies to this topic
  • Thepowderblue
Posted October 01, 2011 - 12:18 PM
I have a new to me yz426f and I am doing my 1st oil change on it.
I drained the oil from both the frame and motor. Idk how much came out. I was told by the people at ride now all my bike takes is 1qt so I bought 2qts. I have both of them in and it still does not even show on the dipstick.
How much do I need?
And is it bad to mix oils. One qt it Honda 10-40 and the other is some thumper something 10-40?
Posted October 01, 2011 - 12:23 PM
Read:
http://www.thumperta...ad.php?t=881284
It takes 1.6 Liters with an oil filter change. Where did you pour the oil in?
Mixing oils is not a fabulously good idea, but most will blend together with no problem.
  • Thepowderblue
Posted October 01, 2011 - 12:27 PM
I drained most into one of those oil pans where you cant see the oil and it had some oil in it before. Plus I spilled most of it so i hosed it down the driveway so I have no idea how much came out.
  • Thepowderblue
Posted October 01, 2011 - 12:31 PM
when I was checking and adding oil I didnt let it run 1st. Should I ride it then check it?
Edited by Thepowderblue, October 01, 2011 - 12:52 PM.
  • Thepowderblue
Posted October 01, 2011 - 12:53 PM
Ok I just needed to run it 1st. I had to drain oil out.
Posted October 01, 2011 - 02:22 PM
Please answer the question: Where did you pour the new oil into the motorcycle?
  • Thepowderblue
Posted October 02, 2011 - 08:49 AM
The dip stick hole in the down tube
Posted October 02, 2011 - 06:46 PM
In that case it should have shown on the dip stick immediately whether you ran it or not. But if you poured oil in it and let it sit a day or more, the oil likely leaked down into the crankcase. You should always run the engine for a minute before checking.
  • 5 replies
  • Hot  50 replies
  • Hot  36 replies
  • Hot  113 replies
