Decomp not dissengageing?
4 replies to this topic
  • Wondermutt
Posted September 28, 2011 - 05:56 PM
Hey all, I own an 02 yz426, had it since new, and recently brought it out of the mothballs from about 3 years ago. I went through it, with the basic maintenance to get her up and going again, oil, filter air and oil, new fuel. I took it out, and the piolt jet was plugged up, ran it like that for about 20 mins or so, up on the main curcuit, seeing if I could get her unclogged, but to no avail. Turned the carb when I got home, and dropped the bowl, cleaned up all the jets and cleared the pilot out. Now I went to start her up, and I can cycle through with the kick starter without needing to pull the decomp lever. The bike is all stock except for jetting and exhaust. The kicker does give some resistance, but nothing like it used to. It used to just stop dead on the compression stroke, now I can move through it with some resistance, when the decomp is pulled it is easier, but it will still go through both strokes without it being pulled. should I be looking at the decomp as the culprit, or something worse, such as the valves or top end itself? Ive never had it torn down, it was always a great runner,always started on te first or second kick, even this last time after sitting for a few years, never hammered on just basic trail ridden with the occasional blast down a sand wash from time to time, but I dont bounce off the rev limiter and mostly am down in lugging mode. Any suggestions would be greatly appreciated
Mutt
  • hoss400
Posted September 29, 2011 - 08:34 PM
Check to see if cable is frozen? does the decompression cam move?
  • Wondermutt
Posted September 30, 2011 - 03:04 AM
Yes, I have taken it all apart. It will start now, but I can still kick it through without having to use the lever, there is more resistance then before, but I am still getting bleed by, which wasnt the case before I cleaned the carb out. My only thoughts are that it must be time to adjust the valves, and put a new piston and rings in her.
Posted September 30, 2011 - 07:13 AM
When you check the valve clearance, be immediately suspicious of any that you find that have more than the specified clearance. Normal wear reduces clearance. If you find one that has more than it should, that valve may be sticking open due to carbon on the valve head or stem.
See if it will "bounce shut" by tapping prudently on the lifter with a punch with the cam lobe pointed up away from it. Give it a tap or 3 and recheck the clearance. If it closes back to a normal range, run some injector cleaner through the next couple of tanks.
  • Wondermutt
Posted September 30, 2011 - 05:40 PM
Thanks for the info, I had never thought of that, will do
  • Hot  33 replies
  • Hot  47 replies
