Flywheel weight for WR450
10 replies to this topic
  • enduro man
Posted September 27, 2011 - 06:30 PM
Does anyone know if a flywheel weight is available for a WR 450 (06 model) and if so, where to get one ?
Thanks,
enduro man
  • redhurricane
Posted September 27, 2011 - 06:49 PM
Why on earth would you want one? Motor's got lots of usable torque as is.
  • motovita
Posted September 27, 2011 - 06:54 PM
And why would you ride a Yamaha in the first place, and why don't you get a two stroke?
Just kidding, try these guys.
http://trailtech.net..._flywheels.html
Edited by motovita, September 27, 2011 - 09:13 PM.
  • enduro man
Posted September 27, 2011 - 07:13 PM
My first Yamaha...bike is great but does not have bottom end grunt for tight trails. Would like to have grunt like my old XR400.
  • enduro man
Posted September 27, 2011 - 07:17 PM
Don't care for two stroke bikes, they cant get up the hills we have here in Texas plus can't stomach the "ring- ding sound".
  • Krannie McKranface
Posted September 27, 2011 - 07:44 PM
If it has stock jetting, stock airbox, and stock pipe, it will always be crappy.
You MUST re-jet to get torque below 4k rpm.
  • wrwest
Posted September 27, 2011 - 09:33 PM
A better option might be a steel clutch basket - you get the added weight and the durability of the steel basket
www.stealtyoffroad.com
  • Just_a_trail_rider
Posted September 27, 2011 - 10:54 PM
The yamaha has plenty of grunt. Is your jetting correct?
What size sprockets do you have.
  • wrwest
Posted September 28, 2011 - 04:52 AM
I run a 12 - 50 works well.
  • jayh300
Posted September 28, 2011 - 05:29 AM
Thanks,
enduro man
when i had my 06, i looked all over for one.. all that were listed were not that much more than stock.. check gearing.. iirc, the 06 was higher geared. i think mine had a 14 t front sprocket and was a one year deal. a 13 and as everyone else says.. re jet..and it was a lot better..
jay... 2 stroke guy in tx...
  • wrwest
Posted September 28, 2011 - 10:41 AM
Look at a 12 front and a 50 to 52 rear . Remove ais.
Rejet . remove zorst baffle if stock.
Fit adjustable leakjet to avoid a bog from idle.
If you need more than this you need to work on your riding techniqe.
