06 yz450 wont shift down from 4th
9 replies to this topic
  • d36yzrider
Posted September 23, 2011 - 09:07 PM
the other day at the track going into a corner my bike would not shift down from 4th gear it will shift up to 5th but wont go down im not sure what it could be I have heard shift pawl so im checking that tomorrow if anyone has any idea what else it could be let me know thanks.
  • gscx
Posted September 23, 2011 - 09:24 PM
Have to made sure that your shift lever isnt stripped?
  • d36yzrider
Posted September 23, 2011 - 09:56 PM
yes the shaft is in good shape and It has a new shifter also. it shifts down but wont go all the way down from 4th to 3rd
  • MANIAC998
Posted September 24, 2011 - 05:43 AM
It could be as simple as something stuck underneath the shifting pawl inside the right engine cover. Just pull off the complete right cover, (not just the small clutch cover) and take alook. Hope it's something simple! Maniac
  • Krannie McKranface
Posted September 24, 2011 - 06:35 AM
Shift fork or shift drum is damaged.
  • wr-426
Posted September 26, 2011 - 08:19 AM
my advice,
avoid running the bike until you figure this out, it's hell when the gearboxes on these fail. i'd get the clutch cover off and have a look around, keep fiddling but you may have to go deeper
Posted September 26, 2011 - 07:17 PM
my advice,
There's nothing to see on that side.....................
  • gscx
Posted September 26, 2011 - 08:06 PM
^Wut?
Posted September 26, 2011 - 09:10 PM
Taking off the Clutch cover will not expose the shift mechanism, so it is pointless. It's all on the other side.
  • wr-426
Posted September 26, 2011 - 10:05 PM
sorry krannie,
i realize there is nothing on that side, just got confused when typing. what i meant to suggest is to get in behind the cover on the flywheel/generator side, and look at the mechanism on the other end of the gear selector shaft. you're absolutely right Krannie, I just used the wrong words.
good luck with it.
